Turn signal switch question???
Old Jan 6, 2016 | 02:31 PM
01fxdxt's Avatar
01fxdxt
Pretty sure one year only,86ish,HD used latching type switch.Needed to press switch second time to unlatch.Must not have been real popular,next year went to computer module control.
Old Jan 6, 2016 | 02:47 PM
Dr.Hess's Avatar
Dr.Hess
Yes, the 86 has click on, click off, latching switches. The 87 has no latch and you hold it down, and no computer control either, just the automotive type flasher.
I would GUESS that the 86 switches are going to be a bit hard to come by. The badlands module would be the way to go.
Old Jan 6, 2016 | 03:53 PM
Tee&Vee's Avatar
Tee&Vee
Spanners, thanks!
Old Jan 7, 2016 | 03:01 AM
grbrown's Avatar
grbrown
Cool
Originally Posted by ohiomike
my '82 FXRS has that as well. ( have to hold ) well I changed stock signals for something less obtrusive ( signals in license plate bracket ) and then they didn't work at all, unless, you manually pushed button on-off-on-off etc. got a badlands voltage regulator or what ever it was called and problem solved. ( still have to hold button though) so, its sucks but could be worse. like others have said, you can update them pretty simple.
Mike, I suspect your new flashers are LED? That will explain why your Badlands works. To get the features mentioned in here you should find there is an alternative module available, which will work your LEDs and also give you press on, press off, etc.
Old Jan 7, 2016 | 03:06 PM
Spanners39's Avatar
Spanners39
Yes, he has fitted a Badlands load compensator by the sounds of it...with the Badlands signal module you don't need a load compensator with LED lamps.
Get the module and sell the compensator would be my advice.
Old Jan 7, 2016 | 07:15 PM
ohiomike's Avatar
ohiomike
yes, Spanners39 I think it was a load compensator. they definitely weren't LED`s this was like, back in the 90`s lol still have bike and it still is working by holding button to flash. bought a 97 softail custom and loved the self-cancelling signals and now have a 06 streetglide with same set-up I think. all three still in my garage
Arnt
Electrical/Lighting/Alarm
Sep 20, 2017 02:32 PM
sporty63
May 10, 2014 03:07 PM
strongwood
Jan 1, 2012 08:57 PM
scheddie
Jun 8, 2007 01:24 AM
FLRider
Mar 11, 2006 04:18 PM
