LED Headlight
Old Jan 7, 2016 | 05:36 PM
bigpappa160's Avatar
bigpappa160
Default LED Headlight
I've read on here that people been changing their old headlight with led's. Do they change the whole headlight or is there a led bulb that you just replace. Also, if so is that all you have to do is take old bulb out and put led bul in? I know if you change the front and rear turn signals you have to put a load equilizer in so the turn signals would work correctly. Seeing that I just got it, Trying to do a little upgrade to my 91 Electra Glide Ultra Classic.
Old Jan 7, 2016 | 06:46 PM
Tee&Vee's Avatar
Tee&Vee
Most guys change the whole lamp. Bulb only is a real serious compromise. Spend the money for the truck lite 7" & 4.5" spotlights. Post pics too.
Tom
Old Jan 7, 2016 | 10:33 PM
WindowMan's Avatar
WindowMan
I only did my bulbs, I really only ride during the day since I need to be around nights for the wife, see my post here.
https://www.hdforums.com/forum/evo-c...-my-led-s.html
Old Jan 8, 2016 | 06:45 AM
0maha's Avatar
0maha
Just did mine.
The headlight is a piece of cake. Just pull the old bulb, pop in the new one, done.
The running lights are a bit of a fiddle. On our old bikes, the leads to the running lights are screwed to the stock running lights. The new lights will have a connector attached to them
You have two options. You can cut the connector off the new bulbs and hard wire them to the bike (that's what I did on mine), or you can buy an adaptor to wire into the bike and plug the bulbs in.
I'm told the adaptor/connector option works, but when I looked at it, everything needs to end up stuffed inside of those little cans, and it seems like it would be a very tight fit.
However you do the wiring, the result is really great. These things are way brighter than stock.
Old Jan 8, 2016 | 07:17 AM
grbrown's Avatar
grbrown
Cool
I have a set of three Trucklites for mine, although I haven't installed them yet.
I have read on other threads that replacement LED bulbs don't work too well and can show you why. These two bulbs are the same type, H3 that fit the dresser oval fog lamps and my Buell headlamps - except the LED won't fit either of them, as it's too big! So that bars them from use in two sets of my lights. The l/h one is LED, the r/h one is a conventional halogen.
As you can see the halogen filament coincides with the location of the bottom two rows of LEDs. The other LEDs will be further away from the sweet spot, in a reflector that is designed for the halogen bulb. That IMHO is why an LED bulb doesn't and indeed cannot provide a decent beam pattern, when in a conventional reflector.
Old Jan 8, 2016 | 10:09 AM
Uncle G.'s Avatar
Uncle G.
This is why I've stuck with halogen bulbs in the car, as replacing the reflector assembly with something else is impractical. LED technology isn't quite "there" yet, IMO to work as a direct retrofit bulb. It may happen in the future, but not yet.
Old Jan 8, 2016 | 10:33 AM
grbrown's Avatar
grbrown
Thumbs up
Since I posted that I've taken another look at replacement H3 LED bulbs and you're right. There are a few that look a little more halogen-sized, but not yet close enough to make it worth buying. They are as cheap as chips, but if they won't fit.....
Old Jan 8, 2016 | 02:35 PM
DMetcalf's Avatar
DMetcalf
I installed the Rivco LED-100 LED bulbs and am completely satisfied with the results.
Old Jan 8, 2016 | 04:21 PM
0maha's Avatar
0maha
Old Jan 9, 2016 | 07:33 AM
grbrown's Avatar
grbrown
Talking
Originally Posted by 0maha
FWIW, this is the link to the Truck-lite set I bought from Amazon: Amazon.com: Truck-lite 7" & 4-1/2" Led Headlight Drive Light Set Harley-Davidson Touring: Automotive
And those of us who ride on the lefthand side of the road, as God intended, will be thrilled to know the 7" is available for us now!
