No start
That's what I do to eliminate a battery or starter issue.
Just make sure its in neutral first......
Doing that would keep the starter on all the time the wire is connected.
You need some kind of switch to cut off the starter when the motor starts.
Just changing the relay isn't a permanent fix.
Sometimes it will work for a while after changing the relay but not for long.
If the problem is the "Dreaded Click" you have 2 options.
1) Clean all the connectors in the wiring harness.
2) Bypass the wiring harness with a jumper wire from the battery.
Depending on which model bike you have you may need to wire in an additional relay to get the second option to work.
In the OPs case (softail) all he would need is a 20 amp fused wire.
A volt meter will tell you what your problem is without endangering anything.
If you are getting full voltage at the green wire then you have to clean the contacts in the starter.
I've had to use this as an emergency measure a few times myself and a few times on friends bikes. If it just clicks when the stater button on the handlebar is pushed there's a high probability this test will help diagnose what components are bad. I always carry a piece of wire with me for this reason. I've had the starter relay on my bike fail 3 times in the last 12 years.
The next day I replaced the ignition switch and all was well....
