No start
Old Jan 29, 2016 | 09:21 PM
  #31
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by texashillcountry
There is a big difference between just a click and the motor cranking over slowly.
If the motor is spinning over slowly I agree that it is probably the battery.
I agree. you know how it is, sometimes you gotta ask more questions.
Old Jan 29, 2016 | 09:29 PM
  #32
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Before I joined the Forum I was fighting the Dreaded Click.
I replaced all kinds of parts trying to fix it.
Now when someone tells me their bike just clicks I automatically think it is the Dreaded Click.
Old Jan 30, 2016 | 06:27 AM
  #33
glidein wide's Avatar
glidein wide
Is the dreaded click described as a click and no start or turn at all , or , a click then a pause before it starts to turn over ?assuming you keep holding the start switch .
Sometimes mine would go right over sometime it would engage, pause, turn and start.
Old Jan 30, 2016 | 08:05 AM
  #34
Fatboy 1993's Avatar
Fatboy 1993
Engage pause turn start
Old Jan 30, 2016 | 08:07 AM
  #35
texashillcountry
Dirt don't hurt
A click and no start or turn at all
Old Jan 31, 2016 | 06:39 AM
  #36
glidein wide
So a second relay on my bike wouldn't clear up the pause, I've always assumed it's because of what stroke it's at,thanks Tex.
Old Jan 31, 2016 | 07:03 AM
  #37
bagga's Avatar
bagga
my 85 has had the pause since it was new in 85. i assume it was on a compression stroke. it always starts so i don't get concerned about it.
Old Jan 31, 2016 | 07:09 AM
  #38
glidein wide
I gotcha, my Twinkie riding friends here it and think there is something wrong, but I'm used to it, good to know it's normal.
Old Feb 1, 2016 | 10:31 AM
  #39
Uncle G.'s Avatar
Uncle G.
"Compression stall" was pretty common on early Evos. In '94, the MoCo juggled the primary and starter gear ratios, to give the starter motor more leverage against the engine, which must have helped. My '94 Softail has never done this unless the battery is near death.
Old Feb 1, 2016 | 11:30 AM
  #40
98hotrodfatboy
Not sure what year the starter kw rating changed from .8 to 1.2 but that as well coupled with the different starter drives and rings ratio really does create that compression lug at start up.
One could always install a 1.4 kw or higher starter but if you do don't forget to up the starter cable and battery cca rating....
