No start
Old Feb 1, 2016 | 11:39 AM
  #41
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Not sure what year the starter kw rating changed from .8 to 1.2 but that as well coupled with the different starter drives and rings ratio really does create that compression lug at start up.
One could always install a 1.4 kw or higher starter but if you do don't forget to up the starter cable and battery cca rating....
Starter cable????????
Old Feb 1, 2016 | 07:07 PM
  #42
98hotrodfatboy's Avatar
98hotrodfatboy
Yea... That would be from the battery to the starter..
like any circuit if you increase the current draw you need to make sure the circuit can handle it. heat buildup due to too much resistance in the circuit can cause premature failure to the starter and wiring. It would be the same as too much voltage drop across the circuit and starving the starter of the required amperage to sufficiently turn the starter...
Old Feb 1, 2016 | 07:11 PM
  #43
texashillcountry
Dirt don't hurt
Yea... like any circuit if you increase the current draw you need to make sure the circuit can handle it. heat buildup due to too much resistance in the circuit can cause premature failure to the starter and wiring. It would be the same as too much voltage drop across the circuit and starving the starter of the required amperage to sufficiently turn the starter...
Are you talking about the green wire that goes from the starter relay to the starter?
FWIW I had a 1.4kw starter for a while without changing anything else and it worked fine for a couple of years.
The reason I took it out was that it was noisy not because something broke.
Old Feb 1, 2016 | 07:42 PM
  #44
98hotrodfatboy
No, the starter cable from the battery positive post.
It's only a suggestion because now you can get up to a 2 kw starter. lots of draw there...
Old Feb 1, 2016 | 07:57 PM
  #45
texashillcountry
Dirt don't hurt
I kinda thought that's what you were talking about but I wasn't sure.
I've never heard it called a starter cable.
As for the 2kw starter the only people here that would possibly help is 1997bagger and bumpandrun nobody else (that I know of) has a motor big enough to need one.
king1pin1
2018+ Softail Models
20
Jul 5, 2019 01:00 PM
Softball LMDM
Apr 29, 2019 06:50 PM
hvywghtchamp
Electrical/Lighting/Alarm
23
Aug 28, 2017 10:10 PM
ArtR
Jul 7, 2014 09:19 AM
Johnny Sotelo
General Topics/Tech Tips
Jun 26, 2014 12:55 PM
