What is this?
Old Mar 11, 2016 | 09:49 AM
Nelz's Avatar
Nelz
Originally Posted by Grey_Fox
So I take that this would just go over the existing one?
Yes, the cap goes over the existing piece.
I tore into mine last night because it looks just like yours. I'm pretty sure the aluminum has a clear coat or some other coating over it, which is what ends up looking so bad, probably because of the heat from the exhaust. I started sanding mine and it already looks 100% better. I have to go back over it with a finer grit and then polish it, but I'll post some photos in the next few days.
Word of warning, however, if you go down this route of sanding/polishing, you have to do the whole thing because otherwise you'll have a line wherever you stop sanding. There are a lot of nooks and crannies, so it's a little bit of a pain to sand. Also, you have to be comfortable with taking the coating off and living with raw aluminum.
Old Mar 11, 2016 | 11:47 AM
Uncle G.'s Avatar
Uncle G.
Thanks for the info!!!
If the ebay cover doesn't work out, then I will have to replace it. As you can see in the pic, the chrome is peeled off and bare steel is exposed.
I will seek the aid of my father-in-law with this since he said he replaced one before.
THIS is the reason I won't ride on roads that have been salted. That's what happens when salt/moisture gets on chrome plated aluminum. The aluminum starts to corrode UNDER the plating and causes the plating to lift and peel. Yes, Uncle G. is an engineer.
Yes, the cover can be removed without disturbing the valvetrain. I've done it. Remove the exhaust system, brake pedal and anything else in the way, then remove the ignition cover and remove the sensor plate and the trigger cup on the end of the camshaft. Mark the position of the "notch" in the sensor plate so you can put it back in the proper place. Rotate the motor until the "notch" in the end of the camshaft is in the "5 o'clock" position and unbolt the cover. There's a special tool you can use to pull the cover off the two dowel pins that presses on the end of the cam to pull the cover. Otherwise, pull on the cover as best you can, while pushing in on the cam with your thumb to keep the cam from coming out with the cover.
Old Mar 11, 2016 | 11:51 AM
Uncle G.'s Avatar
Uncle G.
Harley actually sells a "wipe-on" protective coating for aluminum called "Harley Preserves". It's sold as a "moist towelette" at the dealership. After you clean and polish the aluminum, you wipe this stuff on. After it dries it's invisible, but really works. I treated my fork legs after I sanded off the corrosion and what was left of the clear coat about 5 years ago. I've had no sign of tarnish or corrosion since.
Old Mar 11, 2016 | 12:21 PM
Nelz's Avatar
Nelz
Thanks for the tip about Harley Preserves, Uncle G. I had been wondering about something to put on the cam cover after stripping the coating.
Old Mar 11, 2016 | 12:22 PM
byronk's Avatar
byronk
Originally Posted by texashillcountry
According to the gurus around here you can take off the cam cover (gear cover) without disassembling the motor.
You just have to rotate the motor until the notch in the end of the cam is in the 5 o'clock position and then use something to hold the cam in place while removing the cam cover.
Had to replace the gasket on mine and was able to take it off and re install it without a problem. Just set the notch between 4:30 and 5:00.
Old Mar 13, 2016 | 12:30 AM
Nelz's Avatar
Nelz
I finished sanding and polishing the original piece. Of course I forgot to take a photo before I started, so I can't show a true "before" picture, but it looked a lot like the photo Grey Fox posted at the start of the thread. Here are some photos of the various stages during sanding and polishing. It was a bit of work, but I'm pretty pleased with the results.
I'm a sucker for chrome, so replacing the part with the chrome piece would have been my first choice, or using the chrome cap is another great option, but this was a decent alternative, if you have more time than money.
Attached Thumbnails What is this?-20160310_200140.jpg   What is this?-20160310_205051.jpg   What is this?-20160312_205438.jpg
Old Mar 13, 2016 | 07:51 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Nice job man.
I would add a protective layer like Uncle G suggested at this point.
Old Mar 13, 2016 | 08:01 AM
TPost's Avatar
TPost
That came out nice! My aluminum is really starting to look like crap. What grit paper did you use? I was thinking 1000 grit wet followed by 1500 wet then polish with Mothers.
Todd
Old Mar 13, 2016 | 08:22 AM
glidein wide's Avatar
glidein wide
I've done a lot of aluminum polishing and will try this stuff out...
Old Mar 13, 2016 | 11:52 AM
Nelz's Avatar
Nelz
Nice job man.
Thanks, texashillcountry. I'm definitely going to add the coating. I picked up two packs of Harley Preserve Bare Aluminum Corrosion Protectant at the dealer yesterday (about $3 each). I might do the same to the tranny cover, so I'll apply the coating to both at the same time. The cam cover looks like it'll smudge if I just look at it.
Todd
Thanks, TPost. I used all kinds of stuff, but would do it a little differently going forward. First I used 150 to get the stuff off that was bubbling/peeling, but a much higher grit would have probably worked as well. I went up the chain with the sand paper (320, 600, 1000, 1500, 2000), and did the last four wet with some dish soap. However, the thing that worked best and left it with the finest scratches was some grey 3M scuff pad. I used some Bar Keepers Friend on the center cap. I then used some soft metal compound and buffing wheels that I picked up at Home Depot (http://www.homedepot.com/p/Ryobi-Met...BK71/205642376). They worked ok. There's probably better stuff out there, but that's all I could find locally. Lastly, I used some Nevr-Dull by hand, which produced the most shine.
If I had to do it again, I would go straight to the grey scuff pad and Nevr-Dull, which is very close to what you're describing with the fine sand paper and Mothers.
