Throttle Cable Help Needed
Old Mar 21, 2016 | 08:59 PM
long-boarder's Avatar
long-boarder
Default Throttle Cable Help Needed
Building custom with 99 EVO and stock CV carburetor, using old police handle bars with internal throttle cable. Do not want to change this set up so trying to figure out how to hook solid cable wire to CV Carb. or change out solid throttle cable wire with new braided flex cable , stock for CV. Would have to use a inline cable adjuster to take up the slack. May be nuts but I am sure someone has does this sometime?
Old Mar 22, 2016 | 12:57 PM
tomfiii's Avatar
tomfiii
would need clamp pivot and bracket for cable sheath like older carbs keihen, bendix etc. or adapter like Jim Mosher makes for Indian CV conversion.
Old Mar 23, 2016 | 07:40 PM
long-boarder
Default Found solution? The missing link
Found a guy in Wisconsin that makes a cable splice for small motors (go-karts) that just might be the ticket. Small bracket with bolt and nuts on either end that are made into cable adjusters, they have holes through the bolts for the cables , then has a cable clamp in the middle. So solid strand wire (original) can be spliced with multi strand cable(new). The adjustment on either end would be able to take up slack when needed. Looks like I can also incorporate a spring to assist with shut down of carb. Seeing I am only using one cable on carb instead of two. I believe it is small enough to mount on frame between tanks.
can be seen and bought at fastermotors.net
Old Mar 25, 2016 | 06:58 PM
glidein wide's Avatar
glidein wide
That's a pretty good answer to your own question !!! LOL . You should be thankful to yourself....
Old Mar 26, 2016 | 07:08 PM
long-boarder
Well will see if it works...
97HDSFTL
Sep 5, 2018 05:34 AM
Chaseg08
Jun 25, 2011 11:20 AM
fixedmlc
Aug 10, 2008 08:36 PM
csd4682
Ironhead
May 23, 2008 05:24 AM
tommylee44
Apr 7, 2008 03:34 PM
