Valve stem oil seals
Old Apr 2, 2016 | 04:14 PM
  #41
Dazzauk's Avatar
Dazzauk
Originally Posted by texashillcountry
Man you are stuck on getting those aren't you???
If the bike starts and runs good without them why do you want them????
Ha ha. I guess so.
The trouble is I've inherited a bike which has been my dads for 20 years he's the only one who knows the ins and outs of it in terms of what the compression ratio / stroke is what cams are on it etc etc. But after his stroke his memory is not too good so he can't remember half of what he had done to it.
All I know is compression is high it can be a pig to starts but runs great when it fires up. The noise when it catches wrong is horrid and he tells me that's what it needs.
Unfortunately the only way to find out is to either pay someone to strip it and tell me what's in it and I need oil seals doing anyway or bite the billet and get it done anyway .
Trust me I don't wanna chuck my money around for nothing.
Old Apr 2, 2016 | 06:25 PM
  #42
bagga's Avatar
bagga
before you throw all kinds of money at it, just ride it for a while. if it starts, it's not broke. the noise from the starter is more than likely the starter clutch and not the starter itself. take a deep breath, step back and stop thinking so much.
Old Apr 2, 2016 | 06:48 PM
  #43
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Old Apr 2, 2016 | 07:33 PM
  #44
98hotrodfatboy's Avatar
98hotrodfatboy
Hey Dazzauk, One thing you can do is pull the exhaust and take a look at the exhaust valves to see if indeed there is an oil trail there. If your seals are bad you will see a trail....
Old Apr 3, 2016 | 07:25 AM
  #45
glidein wide's Avatar
glidein wide
Now there's an idea !!!!
Old Apr 3, 2016 | 08:11 AM
  #46
br549A1's Avatar
br549A1
Can I suggest maybe you aren't using the right starting procedure for it? Jap bikes are totally different and start effortlessly. 2-3 full throttle twists with enricher wide open before pushing the button. Maybe you are but I get a nasty noisy kickback on start if I don't take my time and do this then wait a few seconds and do it again if it doesn't start the first time
Old Apr 3, 2016 | 09:09 AM
  #47
98hotrodfatboy
Yea S$S can be pretty finicky like that. A lot depends on your compression ratio as well....
Old Apr 3, 2016 | 05:05 PM
  #48
Dazzauk's Avatar
Dazzauk
Thanks man, I will bear that in mind for sure. Sometimes I do give it a quick twist of throttle. I gues it squirts a quick lump of fuel in to help her start right.
I have the Mikuni Hsr 42mm carb so obviously don't wanna hey loads of fuel in there
Oh maybe a silly question but I don't know the answer. What's the enricher??
Not sure exactly what the ratio is just know they are high compression
Old Apr 3, 2016 | 05:15 PM
  #49
br549A1's Avatar
br549A1
Choke, enricher. You should ship me that Mikuni and I'll send you my CV!
Old Apr 3, 2016 | 05:17 PM
  #50
grbrown's Avatar
grbrown
Wink
I had my original motor modified and tuned, with stroker crankshaft, high CR, cam, flowed heads etc, but the starter could always do the job. In addition to the previous starting tips, when pressing the starter button, make sure to keep it firmly pressed, so the engine turns over until it is running.
If it is recluctant to turn over briskly then clean your battery terminals, make sure they are tight, but also clean and check the other ends of the main battery cables. Check battery condition and claimed CCA (Cold Cranking Amps). If the battery is old or cheap, it may not have the oomph needed.
