Started cam change. Interesting find!
Old Apr 10, 2016 | 10:29 AM
TPost's Avatar
TPost
Originally Posted by kp877
If you look up the "A" vs "B" lifters on google you'll be able to compare yours to the b to see if they were upgraded. Assume you're still putting new lifters in. Also when you order the 3010 get the no gear version and swap your gear, you'll need a press but it will save you some cash and you won't have to worry about mismatched gears.
Thanks for the info. Looked it up on google, it's got the same style clip as a "A" lifter but appears to have a bigger axle than a "A". Todd
Old Apr 10, 2016 | 02:04 PM
Owtlaw's Avatar
Owtlaw
I'd spend an extra 70 bucks or so and do the lifters and the bearing (again) and not have to worry about it for ever. YMMV.
Old Apr 10, 2016 | 06:52 PM
Hackd's Avatar
Hackd
^^^ What he said.
Old Apr 10, 2016 | 07:06 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Where can you get a set of lifters for $70????
Old Apr 10, 2016 | 07:20 PM
glidein wide's Avatar
glidein wide
Used at a swap meet....😤
Old Apr 10, 2016 | 08:10 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Are you serious? Somethings you just gotta go for it...
Old Apr 10, 2016 | 08:23 PM
Prot's Avatar
Prot
Crane Cams big axle lifters 3-2050. I picked up the set of four for $189.95 including shipping.
Old Apr 10, 2016 | 08:38 PM
Owtlaw's Avatar
Owtlaw
OK..... 140. I multiplied wrong. I'd still spend it.
Old Apr 10, 2016 | 08:53 PM
langwilliams's Avatar
langwilliams
I was thinking this too....HD used to sell them for around $25 each, last time I checked they were $50 each.
Old Apr 10, 2016 | 09:55 PM
daven9113's Avatar
daven9113
Originally Posted by TPost
**UPDATE** I just pulled the lifter blocks and cam cover. The lifters appear to be in very good shape. No markings of any sort so in don't know if they are HD of aftermarket. The cam bearing HAS been updated so that is good news! The cam is stock "N" grind. A little oil weeping by the cam cover seal but I will fix that when I put it back together. I'm glad I didn't order the cam bearing tool before I got it opened up. I guess I'm gonna order the VThunder 3010 cam and get her back together. I also picked up a set of stock non adjustable pushrods from my local indy delay for $10. I'll be putting them back in instead of the Crane adjustables Todd
TPost,
Get a light and really look at that cam bearing. Depending on the mileage, I highly recommend that you change it out when putting in the new cam. The bearings will develop wear patterns. I'm no shop mechanic, but I think this is good shop practice. It doesn't take much time when using the blind hole puller that you can borrow from Advanced Auto. Use the old cam to line the new bearing straight, and then use a driver, again borrowed from Advance Auto to seat the bearing. As for the rollers, if they check out, then I would re-use, if you are trying to save some $$.
Attached Thumbnails Started cam change. Interesting find!-20151120_172725-1-.jpg   Started cam change. Interesting find!-20151120_173238-1-.jpg   Started cam change. Interesting find!-20151120_174445-1-.jpg
