I ****ing Hate Motorcycles.....
Old Apr 15, 2016 | 05:53 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by grbrown
That needs at least three hands, at the last count! I use a self-sealing qd valve in mine.
Old Apr 15, 2016 | 05:57 AM
Joe_G's Avatar
Joe_G
By no means - you clamp each side, then cut, then drain one side, then the other. Easy operation.
No room for a quick disconnect on a Softail. And last I looked, they are like $50 - that'll buy a lot of fuel line.
Old Apr 15, 2016 | 06:00 AM
texashillcountry
Dirt don't hurt
I have one on each of my softails.
Old Apr 15, 2016 | 06:08 AM
Joe_G's Avatar
Joe_G
I apologize, I have a twin cam and I"m in the wrong forum I just realized.
But the vice grip trick works on either.
Old Apr 15, 2016 | 06:13 AM
flhchaz's Avatar
flhchaz
I use a $6 liquid pump from harbor freight. The have Long hoses, one in the tank, one in the jug. Just a couple pumps and it flows on its own.
Old Apr 15, 2016 | 06:14 AM
Joe_G's Avatar
Joe_G
I siphon too (but I do it old school) but I've never been able to get all the fuel out of the tank (Evo or Softail) so that's why I posted my tip regarding the vice grips.
Old Apr 15, 2016 | 06:16 AM
flhchaz's Avatar
flhchaz
Well, I guess the one piece tank on me electra glide is easier
Old Apr 15, 2016 | 06:19 AM
Joe_G's Avatar
Joe_G
Nah you're better than me cause my one piece on my Evo Road King was the tank that introduced me to gas all over the floor when I unhooked the transfer hose! I thought sure I had all the gas out.... uhh no not even close. Well a little gas goes a long way on your garage floor I guess.
I knew there must be a better way and that's when I caught the vice grip trick from Redbeard on here, and why I pass it along when I get a chance, trying to help someone avoid the mess I created for myself before I learned it.
Old Apr 15, 2016 | 06:22 AM
flhchaz's Avatar
flhchaz
A little gas does go a long way when its on the floor. With the siphon pump, i can get most of the gas out, then unbolt the tank and tilt it to the back before i take the cross over line off. I'll be doing it a gain soon
Old Apr 15, 2016 | 07:03 AM
Grog's Avatar
Grog
A little gas on the floor just helps you clean up all the oil from the various leaks on the bike !!!
