Then I love them.
Then I hate them.
Then I love them.
Then I pour gas all over the garage when trying to drain my tank so I can pull one side and fix my electrical issues, and so I hate them again.
As much as I hate to see anyone else suffer, it does feel good to see I'm not the only one that goes through this love hate relationship with the bike.
Works great and saves time. Check fuel line size. I can't remember which size I ordered. Worth the investment.
Yea, be super careful with gas. I worked with a guy that was using av-gas to wash grime off of his hands. Some how, I think a cigarette lit that stuff off and he was so badly burned that he died in a few miserable days. Gasoline has a serious bite. Yea, he pulled the fuel hose off of the float bowl, had someone in the test cell turn the fuel pump on, was washing his hands with gas, it lit off, the fuel pump was till on, it was really bad. Could have been a just a spark from static on a cold day. I don't remember how it lit off. Just that gas is safe till it kills you.
FYI...Doing some quick Googling shows that ABS is NOT SAFE for use with gasoline. You may want to see what the manufacturer has to say about that. Maybe they use some proprietary blend of plastic that they just call ABS.
For now, I'll just pinch it off and buy extra fuel line.
And you have to be careful with battery chargers as well. My friend didn't know the trick of unplugging the battery charger before unhooking it to the battery.... of course batteries make hydrogen when they charge and the charger may spark if you unhook the charger while it's still plugged in. My friend was charging his motorcycle battery and hydrogen built up in the battery box and when he unhooked the charger the battery blew up and got acid all over him.
He's fine but luckily for him he wears glasses or it wouldn't have been such a decent outcome.
Another little tip there for what it's worth, unplug the battery charger before hooking it up or taking it off the battery.
