2000 fat-boy with EVO - Help!
Old Apr 18, 2016 | 10:18 AM
jwm9289's Avatar
jwm9289
6th Gear
Default 2000 fat-boy with EVO - Help!
Hello,
My friend has a 2000 fat boy EVO that is running poor. It started with bike sitting and gas going bad. He ran sea foam through the bike, still ran bad so he flushed tank and still has the issue.
He purchased a factory carb (apples to apples) and still has the issue, starts up and runs poor.(Poor- Popping back through the intake, spitting and sputtering) If you pull the choke out it will run okay. He drained tank again, pulled petcock and flushed, new gas, replace intake gaskets and took on a long test ride and still running bad. The bike has a Kuryakan Hyper charge air cleaner assemble.
Things done....
* New Carb
* New Intake Gaskets
* New Vacuum Lines
* Flushed tank, pulled petcock and flushed.
* Installed new high test gas.
Thanks, Jim
Old Apr 18, 2016 | 10:38 AM
tmanbuckhunter's Avatar
tmanbuckhunter
Are you sure he's replaced the intake gaskets? Also, no way it can be a 2000 and an evo.
Old Apr 18, 2016 | 10:51 AM
Owtlaw's Avatar
Owtlaw
I'd certainly suspect either the intake gaskets (between the manifold and the heads) or the gasket from the carb to the manifold. And is the backing plate for the POS Hypercharger holding the carb tight to the manifold?
I also suspect it's a TC or a 99 or older.....
Old Apr 18, 2016 | 10:58 AM
jwm9289's Avatar
jwm9289
6th Gear
Your correct, it's not an evo.
Old Apr 19, 2016 | 07:33 AM
grbrown's Avatar
grbrown
Suggestions above remain good ones. The hypercharger is not a wise installation IMHO and is renown for causing running problems. Inlet and exhaust leaks are a real possibility, from what you describe, so attend to those first. If between the two of you you cannot sort it out quickly then save your sanity and take it to a local indy. Unfortunately there is only so much we can suggest from afar!
jwm9289
Carburetor Related
Apr 20, 2016 02:31 PM
busterman2
EVO
Mar 22, 2013 04:08 PM
danrider44
Engine Mechanical Topics
Sep 1, 2011 06:29 AM
slabman
Exhaust System Topics
Feb 28, 2009 02:39 PM
gabesoftail
Dec 4, 2007 01:35 PM
