Ive never done any engine work on a motorcycle to speak of and have been chasing a nasty vibration in my bike for awhile. It comes in at around 30mph and goes away at 70. The best way I can describe it is the way my Mercedes felt when the hydrolic motor mounts collapsed . It feels like the engine is sitting directly on the frame or, possibly a cracked frame. The vibration in the floor boards is horrendous . Its always had some vibration in the right floor board at highway speed but the left was always smooth. I have spent hours on my back with the bike in the air and cant find anywhere that the engine or exhaust is touching the frame. I cant find anything broken or worn. The front engine mount appears OK. I dont see any cracks. The vibration is definitely engine RPM related. I know these engines vibrate due to their design but, I dont think it should be felt this much throughout the whole bike. Now, to get to my questions. Remember, Ive never pulled a harley engine. besides the front motor mount and top engine mount, what else holds the engine in the frame?
I have only ridden an '80 FLT and a Twincam Ultra, as far as rubber mounted baggers. Even my shovel (FLT) was really smooth.... For a Harley. They both still shook.
The engine is connected to the transmission through a solid mount, and the transmission is tied into the swing arm bolt, right? I can't honestly say, I've looked at the underside of an Evo dresser. I'm trying to remember how my Evo Superglide was connected, but it's been a long time.... It doesn't necessarily have to be rubbing the frame, but, if either of the mounts is worn or misaligned/maladjusted, it will shake the whole bike. Isn't there something in the Service Manual about the engine mounts?
Been down this road. I would encourage you to do little until you get one of the guys in TX to swap rides with you so you get a good comparison and you of another Evo. I found tons of stuff wrong on mine chasing vibration but never cured it. It does run 1000 times better now though! I can't believe how many things I found wrong but like I said, nothing cured what I was looking to resolve.
Vibration in a rubber mounted Evo is from mis-alignment in the rubber mount system. Your '89 is old enough the front rubber is most liekely squished or deteriorated. Basically the motor bounces on the front rubber as it pivots on the swingarm pivot shaft. Another common problem is the rubbers back at the swingarm under the football shaped plates with the chrome covers hiding the swingarm pivot shaft. If you don't have 1 get a good H-D Manual. After changing the (20 rubbrs in the rear and the 1 in the front align per the manual.
Basically, get it upright on a lift, place (2) weights in front of and outside each side of the front tire, (I use car jackstands). Tie string line to the top of a stand, go back around the rear tire and up to the other stand and tie it off. make the string line as high as possible on the front and rear tires. With the string just touching the front of the rear tire on both sides, the front wheel at rest straight should be centered in between the stringlines. Adjusting the front motor mount heim joint will correct misalignment. There is also a heim jointunder the tank to the heads. Get a manual before you decide to make any adjustments on the upper heim joint ASM
Make sure the rear tire is properly aligned in the swingarm. The proper wat to do this is pop the chrome covers off the pivot shaft. You can bend a wire coat hanger to a long L and sticking the short end into the pivot shaft center hole, mark the center hole of the wheel axle on the long side. Take L Gage to other side and insert into pivot shaft to confirm axle is square in swingarm relative to swingarm pivot shaft
Thanks. Yes, I have done that and it is aligned perfectly.
