Some Basic Questions.....Horrendous Vibration
Old Apr 27, 2016 | 08:32 PM
Joe_G's Avatar
Joe_G
Originally Posted by 89FLHTC
I did completely remove the front motor mount and it looks good to me. No cracks, tears, etc. and it is still soft. Its the old style mount made of the softer compound so, I kinda hate to replace it with the new style mount.
Can you rev the engine to 2500 or so which is your vibration range in neutral on the stand, set the throttle stop and look really closely at the engine mounts to see if you find anything amiss?
Old Apr 27, 2016 | 08:36 PM
Dr.Hess's Avatar
Dr.Hess
Your difficulty putting the top motor mount back together is indicative of a sagging drive train. I would start with a new front mount at least.
Old Apr 27, 2016 | 08:46 PM
89FLHTC's Avatar
89FLHTC
OK, I'll give it a try. I never did find the "thingys' in the rear they were talking about. The swing arm bushings look good though. Always something on these old bikes.... Wouldnt trade it for a new one though.
Old Apr 27, 2016 | 08:53 PM
Dr.Hess's Avatar
Dr.Hess
Swing arm bushing thingies behind the passenger floor board mounts. Those, the top mount and the front mount are what hold the drive train in place.
I had a shovelhead that would shake something fierce at like 63 MPH. Upper motor mount was cracked in half. You couldn't see it under the tanks.
Old Apr 27, 2016 | 09:10 PM
89FLHTC's Avatar
89FLHTC
If I were to shim my current motor mount to raise it a little, would that help any if the mount is sagging? Maybe as a test before shelling out $60.00 ?
Old Apr 28, 2016 | 06:33 AM
Scrmnvtwins's Avatar
Scrmnvtwins
Replace the soft worn out front rubber you have already removed with a new firm OE replacement. Not saying it will solve the vibration however you already have that 27 year old piece of rubber out and it would be a shame to bolt it back in just to replace it in a month or 20.
Old Apr 28, 2016 | 06:49 AM
Owtlaw's Avatar
Owtlaw
Agreed. Spend the 60 bucks and be happy, even if it doesn't solve the issue. Needs doing.
Old Apr 29, 2016 | 03:30 PM
falconbrother's Avatar
falconbrother
I replaced my front mount and over time the two front bolts came loose and one lost the nut completely. It vibrated bad like that. Once I fixed it it calmed way down. A loose or broken engine mount vibrates but good.
Old Apr 29, 2016 | 05:30 PM
Beemervet's Avatar
Beemervet
FYI
https://www.hdforums.com/forum/touri...tor-mount.html
Old Apr 29, 2016 | 05:37 PM
Beemervet's Avatar
Beemervet
Damn...... I just ran across this:
https://www.hdforums.com/forum/evo-c...brate-but.html
What's taking so long?
Ultra Pearl
Sep 27, 2017 07:09 PM
Scouser1
Apr 14, 2012 08:09 AM
Gummiente
Oct 28, 2010 11:54 AM
07yellowglide
Apr 4, 2010 09:15 PM
TowJam
VRSC Models
Oct 17, 2007 04:17 PM
