Don't know if I did some real damage to the clutch or a cheap repair. Pulled the clutch to put the bike into gear. There was a loud pop and the clutch went soft. Thought the cable broke but it was still good. Looked at the trans and the arm were the clutch cable ties in, you can spin it freely by hand
99% sure its your clutch release finger on the carb side of the bike. Takes about 5 mins to pull the outside cover to inspect (if you lean the bike to the left you should not even lose any tranny oil). Mine popped on a ride into work a couple of months ago and I was able to replace it after work as i went and bought the finger + 2-3 tools needed at lunch.
Be careful and do not ride it as the fingers can get into the tranny gears. Plus while you have it apart check the roller race that the fingers hit as the rollers have a history of giving up the ghost and leaving the two bearing surfaces rubbing against each other.
