Building an 89" Stroker
Old May 15, 2016 | 11:20 PM
ElectraRoadKing's Avatar
ElectraRoadKing
Default Building an 89" Stroker
So I just found out that my front rod bearing is laying down. So since I have to go that far into the engine, I figured that I'd go with some S&S wheels.
The question that I have is what kind of cam would be a good idea to get with it.
I have an 89 FLHTCU. Has a super e carb, V&H pro pipe, and single fire ignition. The pistons will be the S&S 9.25:1 pistons.
The EV13 is supposed to be a good cam for a bagger but my buddy suggested the EV51. Even thought about the S&S 510V.But given what I have now, and the direction that I am going, I'm not sure which direction to go. The EV51 does sound like a good time when I'm in "spirited" riding mode.
Kinda looking for people who built 89" strokers in baggers and how they like where the torque comes in at.
Old May 16, 2016 | 05:30 AM
grbrown's Avatar
grbrown
Cool
I can't claim to have built mine, I got a local indy to do it. He used JIMS parts, KB pistons of around 10:1 and a Crane cam, although I don't recall which one, also ported the heads. You will also need a different ignition system, to provide a suitable advance profile and again mine was Crane. I say 'was' as I have moved on, to an S&S 107"!
If you are going to have your crankshaft built for you then ask for suggestions of cams, ignition etc. Things have moved along a lot since I did mine and there are tuning parts available today that weren't around back then. Also consider having your heads ported, to get the best of your build. It's only money....
Old May 16, 2016 | 06:05 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
An 89" set at 10.0 cr and a Wood 6H cam will hover at 100/100.
Built many like that, some with over 20 years in service.
Scott
Old May 16, 2016 | 06:44 AM
grbrown's Avatar
grbrown
Advice doesn't come any better than from Scott!
Old May 16, 2016 | 08:07 AM
galtjunk's Avatar
galtjunk
I have an Ultima 89" stroker kit with a Crane cam, heads ported to match an Edelbrock manifold with a Super G in my 95 FLHT. I am getting 80 and 80.
Most of my riding is above 5000 feet.
What else should I do to see 100/100?
Old May 16, 2016 | 02:20 PM
daven9113's Avatar
daven9113
Scott
If you build out to an 89 cubic, do you need to look at other components on a 1989 EG, such as clutch, tranny etc...?
Old May 16, 2016 | 08:22 PM
1997bagger's Avatar
1997bagger
Scott
Have ran this same combination for 6 years before going to big cubes, a solid set up that provides low power that will go deep into rpm's when called upon.
Your EV51 has 256 and 252 duration with 44 intake, it will be a marshmellow down low with the compression you mentioned, not ideal for a big bike, will need to get to 3500 before giddy up comes in. The 4 5/8 stroker kit takes a flat top piston that puts it around 9.75-1 so a dome piston isn't going to work on the street because it will be in the 11-1 range, plug in the Big Boyz compression calculator to check desired compression, it is really important for cam selection
If you do some head work with springs the W6H will work, if no head work with stock springs the Comp Cams 3010 is easy on the valve trane, W6 or EV27 is badazz but will need some detailed lifter adjustment, personally think the EV13 will hit hard with the 4 5/8 flywheel but shoot it's wad early and not let the stroker work thru the midrange
Old May 16, 2016 | 08:24 PM
1997bagger's Avatar
1997bagger
Extra plate clutch will help and a stock 5 speed will work fine.
Old May 18, 2016 | 01:39 AM
ElectraRoadKing
When I look online, I don't see much listed for 4 5/8" stroke in terms of piston selection. So that is the reasoning behind going with S&S pistons. The 10:1 ratio sounds more appealing to me. So if any of you know some specific part numbers, or who to call for that, I'd appreciate it.
Also, it seems as though .510" lift is the limit with stock spring. Then you go with the beehive style springs, and then you have to cut reliefs into the head. At what point do you move from high lift springs alone to needing machine work done.
I wasn't planning on doing too much to my heads this round except for cleaning up the ports a little.
Old May 18, 2016 | 03:59 PM
1997bagger's Avatar
1997bagger
My apologies on numbers, you are correct on the 9.25 flat tops, what the formula is cutting stock heads down to 75-76 cc's to get the compression at 10.0-1. What is know about performance engines is achieving compression with flat tops is a goal, dome pistons have more rotating mass and detonation prone with flame travel direction being altered causing hot spots. 10.1 is a good target with flexible timing adjustment well within a 2000I ignition running early intake closing cams on a big bike so detonation isn't a problem.
Cast flat tops has been the only pistons available but I noticed some forged flat tops somewhere, not aware of domes so maybe you are ahead of me on pistons if you found domes listed. Still take a look at doing the heads for $600 and so many giddy up cams and flat tops can come into play that makes the 89" optimal
