Took my handlebars off
The throttle and clutch cables were perfectly straightforward (+6 on both), but the brakes have proven to be a bit of a fiddle.
After much research, a few phone calls, and considerable time over at the indy next door pouring through catalogs, here's what I've settled on:
Going with Russell "Renegade" brand. In case anyone goes through this and is interested, here are all the individual parts (the numbers are from the Drag Specialties catalog):
1742-0016 - Junction block (this is the thingy that attaches under the lower triple clamp)
1741-0066 - Lower brake lines (need two, obviously). These are 12" long.
1742-0019 Lower banjo fittings. Because of the Wilwood calipers I put on, I am going with 35 degree banjos instead of 90's here)
1741-0075 - Upper brake line. I test fit the bars, ran some rubber tubing, and came up with 28" as what I need.
1742-0017 Upper banjo fitting. Went with 90 degrees on this one.
1742-0360 Decided to splurge and get nifty, matching, allen head banjo bolts.
Schedule wise, it's going to be close. The clutch and throttle cables are supposed to arrive tomorrow, as is an assortment of electrical bibs and bobs I ordered to do the wiring. Assuming all that shows, I've got the long weekend to get all that sorted. The special one-piece top clamp from Wild 1 is also supposed to show up tomorrow as well.
The brake parts aren't arriving until Tuesday. That doesn't leave a lot of room for error if something doesn't fit or is the wrong part.
Minor setback on the bars. The risers on my bike are about 1/32" too wide. I'm going to Dremel out a bit of clearance and that should be sorted. The other thing that may present an issue is that the fork lock stuff is located right under the bars where the wiring will exit. Hopefully everything can be squeezed into place. Worst case is the fork lock stops working. I suppose the really worst case is that I have to remove the fork lock stuff. No biggie either way since I never use it.
The bars are thicker than the stockers, so Wild 1 says to just not use the rubber grommets that surround the bars going into the fairing. That makes sense. But I am also wondering how the brake line will fit, and am thinking I may end up having to Dremel a bit of clearance in the lower fairing to make sure the line doesn't rub.
So my best case right now is to have it all buttoned up Tuesday night. My worst case is that something doesn't fit, I'm scrambling on Wednesday to re-order parts, and putting it together Thursday before we leave on the trip.
What could go wrong with that?
I see you have all the brake parts paid out, I have to change out the brakes on mine as the Russells that are on there do not seem to be take-apart-able. I was looking at one of the full systems that JP offers but now I'm wondering if your piecemeal system might be a better way to go (hopefully cheaper). Did you consider a prefab system or were you just horny to see if you couldn't make Mr Murphy mad?
As far as the reservoir, I'd run the trip with air (capped) and see how it performs. If it's good OK, if not an instrument supply house or sample supplier would have various size stainless cylinders.
The parts you have removed will only go back where they came from so don't freak out mate.
