Fork alignment help needed
With the help of everyone in this forum I rebuilt the forks and calipers on my new to me 1996 fatboy, thank you !
So after putting everything back together I have noticed my forks are not aligned meaning my handlebar are slightly (I would say probably a 6°) turned to the right when rifing straight
What I did wrong was with the excitement of putting everything back together I did not tighten everything slowly quarter turn at a time I tightened one side and then tighten the other side all the way and I am guessing that's where I went wrong
So currently I have the fat boy jacked up on a motorcycle Jack with both the front and the rear wheel off the ground I have loosened the axle bolt and the pinch bolts and the calipers.
Basically I loosen everything from for caps down,, I have NOT loosened up the fork caps.
What is the best way for me to alight the forks from this point?
"Seems" to be okay , but the fat boy has the chrome plate and the head light hanging of to side so it's hard for me to gauge.
Any tips at this point ?
BTW a bent handlebar top clamp will make [force] your handlebars crooked also...
There is nothing to align on your forks...if your handlebars are crooked it is in the risers...you can put your wheel against something solid and straighten it up...but it won't stay long...new riser bushings are the cure.
The idea of loosening the caps or just upper and lower tree pinch bolts with the front axle or wheel in place should settle all square with the world. Betting it is already square tho.
Some bars can be tweaked (bent) easily but the bushings are a real good bet with what you describe.
WP
