Screamin Eagle Side Car belt is the cats azz, has taken every thing a big cube engine can throw at it and sure as heck don't baby the White Bike. Chains are for chain driven wallets or pirate riders sporting chain driven wallets
I don't remember which one of my bikes it was but the FSM recommended replacing the sprocket bolts as well. That or maybe it said you could use the sprocket bolts up to x times then they had to be replaced. Anyway, I'd read up on that section just to be sure.
As long as you're replacing the belt, I'd check the swingarm bearings too. I'm sure you'll already be inspecting the clutch plates.
Saw that a member locked his rear wheel today when the rear sprocket bolts came loose. Thankfully he's ok. He'd just purchased the bike; so it's not clear who didn't follow the factory procedure for replacement/locktite on those bolts but those are not bolts to mess with as failure back there is very bad.
It's been a Twinkie issue for a while. VIVA LOS EVOS!
