Drive belt and what else?
Old Jun 16, 2016 | 07:21 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
If you still have 1990 model year parts on the bike, make sure you use the upgraded pulley hardware: pulley, spacer, oil seal, lock plate and bolts, pulley nut (1995 model year parts).
Also replace:
Inner primary bearing inner race (on mainshaft)
Inner primary bearing outer race and seal (inner primary cover)
Quad seal (under pulley spacer)
Shift shaft oil seal (inner primary cover)
Starter jackshaft oil seal (inner primary cover)
Consider removing the gearset, and replace the springs on the shifter shaft/pawl.
How many miles are on the bike?
Old Jun 18, 2016 | 06:19 PM
Gunslingertom's Avatar
Gunslingertom
Originally Posted by dan89flstc
how many miles are on the bike?
83000
Old Jun 18, 2016 | 07:48 PM
hardheaded's Avatar
hardheaded
hd's side car belt is strong and will last alot of miles. have a friend that was breaking belts all the time, he's not broken the sidecar belt in the last 6 years. new pulleys and replcae the locking plate and every seal and gasket you can.
Old Jun 12, 2018 | 12:15 PM
Pdqtom's Avatar
Pdqtom
4K, no way!
On my 2012 FLHTK I had the crank go south. They pulled the motor to discover the noise. I came up with a new 2015 take off motor and the installed it for me. I asked if now was the time to change the belt, he said that were already there, now would be the time. Total for all labor and the gaskets, fluids and the new belt was $1170.00. So four grand is a bend over price if I ever heard one. My Indy is Rev's cycles in Bastrop, TX.
This may be one of the reasons so many are moving here from California!
Old Jun 13, 2018 | 07:16 PM
Kingglide549's Avatar
Kingglide549
The shifter lever on the transmission, they all go bad.
Install a "Ball" starter clutch , seals and primary bearing.
A belt system might be a great idea, I am doing mine right now.
It lightens the drive train 22LBS!
berndog
Shovelhead
18
Jul 17, 2012 11:56 PM
Temple
Sep 15, 2011 07:13 PM
jman92627
Jun 3, 2009 12:47 PM
gabulldog
Apr 20, 2009 10:00 PM
quigley
Jun 21, 2008 06:49 PM
