Drive belt and what else?
I was running a little late this morning and gouged on it kinda hard, down shifted when I should have up-shifted resulting in a broken belt. I was however, able to coast the rest of the way to work, and clock in on time.
Question is this - Besides the drive belt, what else should I change or upgrade while I've got that much of it apart. It's getting a new tire and front sprocket. The sprocket is quite wore out and this is the failure I've been looking forward to (believe it or not) so I could replace that sprocket.
Baker Transmission comes to mind first.
Then what the hell since you have the primary off and the tranny out might as well drop in a big inch S&S motor.
That S&S motor will need a better clutch, starter, and exhaust....
You do know that Baker now has a reverse gear that allows you to do burnouts backwards don't you???
Originally Posted by Dr.Hess
Personally, I believe in changing out both sprockets and the belt at the same time. But that's just me.
Okay, rear sprocket too then.
I think that should do it for now!!!
Probably will have to pass on the trans, although reverse burnouts are intriguing.
Don't get a light weight aluminum front sprocket unless you want to be in there again in 25 K miles. ask me how I know.
Replace as many seals as you can while you're there.
I wouldn't even think about another belt... Put a chain drive in. They are quiet and can take anything you throw at it... Zippers has reasonable paint to match kits for $400. You'll never worry about it again. And chain wax doesn't fly all over the place........ask me how i know......
The last chain I had chain wax did fly everywhere and it seemed like I was constantly checking the chain tension.
Granted I was riding more often then but there is no way I'd go back to a chain.
