Hard finding Neutral - Clutch Adjustment
Old Jun 29, 2016 | 06:42 AM
happyhab's Avatar
happyhab
Default Hard finding Neutral - Clutch Adjustment
Yes, I have read a ton of threads and have seen advice on just about everything. I understand there are a lot of factors to consider. Having considered all of the factors, here's what I offer up for your review.
My '95 FXDWG calls for 890-1065ml (30-36 oz) of oil and I am in that range for sure with HD fluid. Previously using HD fluid and didn't have an issue with finding neutral for the most part hot or cold.
As I just replaced the motor and had primary tore down, I'm assuming the clutch my not be adjusted perfectly.
It will go in and out of neutral like butter cold. Clutch lever free play is 1/16-1/8" which again I believe to be by the book.
Primary chain adjustment, by the book on cold setting, but have not check the 'hot' play yet.
So would you think it loosen or tighten up the play in the clutch to find improvement, or could it improve either way?
Old Jun 29, 2016 | 05:42 PM
happyhab's Avatar
happyhab
Little bit of throttle seems to be the trick.
Old Jun 29, 2016 | 11:36 PM
daven9113's Avatar
daven9113
I think you should run 32oz (1 QT). Makes it easy to remember.
If all you say is good, then I would back out the adjuster screw a quarter of a turn. I think the primary chain is checked cold at several positions, and adjusted at the tightest position. Have never checked it hot.
Keep at it, until you get it. Good luck.
Old Jun 30, 2016 | 04:30 AM
grbrown's Avatar
grbrown
Wink
Your clutch is the same as in my 1990, which I've owned from new. A few observations from over the years!
  • Fill with oil to the correct level, as per your owners or factory service manual, don't just pour in a fixed quantity! The level is there for a jolly good reason.
  • When practical engage neutral as you roll to a stop, not after you stop - it's a darned sight easier that way.
  • I adjust my cable so there is very little slack at the lever, less than 1/16". It helps a little.
  • When the clutch gets hot, such as in heavy traffic, I haven't found any way of engaging neutral, other than pulling over and stopping the engine.
  • I have just installed a set of Barnett +1 clutch plates, of which I have heard that miracles can happen, but have yet to ride with them to confirm that. Until them I had my original stock clutch plates.
  • In changing plates I discovered that my pressure plate was disintegrating around the C-clip recess, I have no idea what affect that may have had, but now have a new one. Check yours!
  • Check if you have a device to reduce lever effort, as they also reduce clutch lift and adversely affect clutch release.
Old Jun 30, 2016 | 04:35 AM
grbrown's Avatar
grbrown
Wink
There is further related useful discussion in this current thread.
scott7d
May 9, 2019 03:19 PM
Jag Jim
EVO
28
Oct 23, 2018 12:02 PM
stevedrum4578
Jun 15, 2015 12:42 AM
jmass
May 12, 2010 10:58 AM
rgsamsel
Apr 21, 2006 12:41 PM
