Replacing front blinkers
Old Jul 28, 2016 | 10:37 AM
Uncle G.'s Avatar
Uncle G.
Originally Posted by tspider2000
Uncle G, did think about that. I'll try that when I get off work. Thank you.
Went through this when I changed my front blinkers. All the wiring on mine was black, so I had to test it by "trial and error" to get it right.
Old Jul 28, 2016 | 11:06 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Texashillcounty, I bought this from eBay and it didn't come with instructions. Crazy me, I know.
Then look up the model number at the manufactures website.
The instructions are out there somewhere.
Or you can do as Uncle G says and just do a quick connect till you get it right then solder them into place.
Actually that is probably the quickest way to do it as you don't have many options for combinations on your wires.
Old Jul 28, 2016 | 12:37 PM
Yankee Dog's Avatar
Yankee Dog
time to get/break out the multi-meter or a test light. YD
Old Jul 29, 2016 | 09:08 AM
tspider2000's Avatar
tspider2000
6th Gear
Default Blinkers
Than yall for yalls help. I switched the wires around, and I have blinkers. The third wire coming from the new blinkers, are not connected to anything, and the blinkers and marker lights work. Should I connect both of the ground wires to the bike just to be on the safe side, or should it matter. I'm just glad my blinkers and marker lifts work as they should.
Old Jul 29, 2016 | 03:39 PM
Uncle G.'s Avatar
Uncle G.
As I said, the ground for the turn signals is already through the frame. The ground wire is provided in case the turn signals are mounted to an insulator (like a rubber mount). In your case, it's not needed, so if it were me, I'd remove the unneeded wire.
JRfromDK
Apr 25, 2018 03:50 PM
tspider2000
Jul 27, 2016 05:14 PM
BLACK-KNIGHT84
Feb 7, 2016 12:44 AM
Rdizzy
Mar 24, 2011 03:31 PM
