No, not of you're only an "oil leak monitor." Seriously. If you see oil on the motor or under the bike find out where it's coming from and fix it. It's a machine and it's not going to heal itself!
Actually there have been cases of bikes that ran synthetic oil and having a leak then switching to dino oil healing themselves.
did you ever find out where it was coming from? Mines leaking at that same bolt
Originally Posted by Sorg67
It drips from the primary casing bolt at the bottom near the back. That is nor the source. There is a drip line from the inside running down to the bolt.
did you ever find out where it was coming from? Mines leaking at that same bolt .
