Update: 1992 FLSTC Interstate Challenged
Old Aug 15, 2016 | 10:51 AM
Uncle G.'s Avatar
Uncle G.
Originally Posted by Owtlaw
Final drive ratios on Softies and Touring are the same, I believe. The ratio went from 3.36 pre 94 to 3.15 94 and later. (Change was in the primary, BTW) I'm doing this by memory, so if the ratios aren't exact, I know they are close.
The ratios are and aren't the same depending on the year in question, so you're both right, sort of.
From '84 to '92, all big twins had a 3.38:1 final ratio. In '93 Softails changed to a 61 tooth rear pulley giving them a 2.94:1 final ratio, Dynas and baggers remained 3.38:1. In '94 the MoCo added a tooth to the front primary sprocket on all big twins and reverted to the 70 tooth rear pulley on the Softails, so all '94s had a 3.15:1 final ratio. From '95 to '99 the Softails used a 65 tooth rear pulley for a 2.95:1 final ratio while the other big twins stayed with the 3.15:1 ratio.
This applies to US/domestic models only. International models had different final gearing depending on region.
byersmtrco
Jan 5, 2018 12:14 PM
kingkingking
Oct 12, 2011 04:58 AM
avetter11
Oct 9, 2010 12:38 PM
boochm37
Welcome Area Only
22
Jun 2, 2010 12:10 AM
PTAG
Nov 30, 2005 02:26 AM
