shaking bad on hard accelerating
Old Aug 17, 2016 | 04:22 PM
alex17's Avatar
alex17
Stage II
Default shaking bad on hard accelerating
Hi I purchased a wrecked 96 hugger that had a 1200 conversion done to it. It wasn't that bad clutch lever, forward controls, and tank. My problem is when I get on it hard it shakes bad, If I run it at same rpms and speed not accelerating I don't feel the shake. I have looked at the mototr mounts I don't see anything wrong but that doesn't me so ...any suggestions.
thanks
Old Aug 17, 2016 | 06:30 PM
Ruggs59's Avatar
Ruggs59
I would think even a sporty would have an upper motor mount under the tank. Id look there.
Old Aug 20, 2016 | 12:24 PM
Hey Man's Avatar
Hey Man
^^^ Yup.
Old Aug 20, 2016 | 05:13 PM
Electric Greaseball's Avatar
Electric Greaseball
I had a wobble shake and it turned out to be a weak factory shock on one side which surprised the heck out of me as they weren't that old at the time. Tires showing any signs of abnormal wear? Check swing arm bushings? Rear wheel alignment? Wheel bearings? Fork oil level? Motor mounts first, make sure the engine is correctly aligned with frame/Rear wheel.
Might be a good place to start anyway?
Old Aug 20, 2016 | 05:58 PM
Crashone's Avatar
Crashone
If it was wrecked I'd check the alignment and look for broken mount bolts. Double check the front engine mount, loosen the main bolt and run the bike, tighten it back down and see if that changes anything.
Old Aug 20, 2016 | 06:05 PM
Dr.Hess's Avatar
Dr.Hess
Shakes or vibrates? It's going to vibrate, especially in a solid mounted 1200 CC bike. Check the frame too.
Old Aug 26, 2016 | 08:53 AM
alex17's Avatar
alex17
Stage II
I found it there was a washer/spacer on one side of the front motor mount. It still vibrates but when I hit 3000-4000 I couldn't read the spedo or tach now I can and the vibration is all over the bike it fells more solid. thanks guyes for advice
Old Aug 26, 2016 | 10:01 AM
Racepres's Avatar
Racepres
Especially if it was an 883 and we don't know who "built" it!!!!
wastedranger
Nov 13, 2019 03:51 PM
tmultra
May 15, 2018 02:24 PM
Tjessie87
Oct 8, 2016 07:41 PM
Fester the Fox
Oct 11, 2015 04:39 AM
rauchman
Jul 29, 2015 09:10 AM
