Clutch adjustment help needed.
Old Aug 24, 2016 | 08:27 PM
engr146's Avatar
engr146
I will update tomorrow after testing new adjustment or cable replacement.
Omaha! Hope ur clutch is better!
Old Aug 24, 2016 | 08:41 PM
golfblues's Avatar
golfblues
The cable adjuster will not give a earlier catch point. You have to adjust the clutch behind the derby cover. There is a range and you're on the wrong side of the range. I don't have my manual but I did my clutch and it caught way too early. I redid it and it by adjusting the nut a little more and it is perfect now
Old Aug 27, 2016 | 03:01 PM
AlanStansbery's Avatar
AlanStansbery
On the subject of adjusting a Harley clutch, there's a procedure floating around on the internet called something like: "Hippo's clutch adjustment", or words to that effect. It's slightly different than the 'factory' procedure and works pretty well. Hippo was a Harley 'wrench'; I don't think he's with us anymore (passed).
Alan
Old Aug 27, 2016 | 03:10 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Alan
I've never heard of that.
Got a link?
Old Aug 28, 2016 | 11:58 AM
engr146's Avatar
engr146
Ur rite! cable adjust won't do grab point ,I backed off screw 1/2 turn I should backed off full turn.bike is fine no slipping and clutch fully engaged.I had durby cover open and wind picked up and I rushed it.I'm getting back in there and readjust to full turn.
Old Aug 31, 2016 | 06:45 PM
engr146's Avatar
engr146
Perfect 1 full turn ,new locknut and cover screws, clutch grabs rite where I like it and back to the 1/8" recommend slack in cable.I thought maybe my cable was stretched ,not. I will replace over winter.thanks u guys for ur input.
Old Aug 31, 2016 | 06:49 PM
golfblues's Avatar
golfblues
So why do you feel you need to replace the cable over the winter?
Old Sep 1, 2016 | 10:49 AM
corliss@bakerdrivetrain.com's Avatar
The farther out on the handle it engages the better, when it engages at almost the very end it means you are getting the most throw you can get. Which is a good thing.
Old Sep 1, 2016 | 11:24 AM
engr146's Avatar
engr146
1/2 turn just seemed too far for me.when I went a little less than full turn it seemed better for me,about 3" from grip it just starts to grab and then was able to make sure when let out I was fully engaged w/1/8" slack space between handle and cable end. Also when I roll bike back in gear ,clutch in,Im getting less drag .my braided cable is at least 5 yrs .old and coating at ends is ageing. I guess I just would feel better before a longer run knowing I have a new cable that I know how old it actually is. Thanks Mark for info I didn't know that!
da-lou
Mar 12, 2013 10:52 PM
Dew Me
May 11, 2012 10:02 PM
barnzee
Jul 4, 2011 11:40 AM
Indy Road Dog
Apr 23, 2011 09:08 PM
jgcable
Oct 22, 2007 01:19 PM
