Could it be a bad primary chain
Old Sep 1, 2016 | 11:19 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by Plumbwader
It was the primary chain. Swapped it out clacking gone
Anything obviously wrong with the old chain?
Got any idea why it was making the clacking noise?
Old Sep 2, 2016 | 06:24 AM
Plumbwader's Avatar
Plumbwader
No obvious signs of wear but it did have some really tight spots in it.
Old Sep 2, 2016 | 06:45 AM
texashillcountry
Dirt don't hurt
Thanks for that.
Mine has been kinda noisy but I couldn't find anything wrong with it and nothing is broken so I've been ignoring it.
Guess I'll throw a new chain at it and see what happens.
Old Sep 2, 2016 | 09:24 AM
Taggs's Avatar
Taggs
I have seen primary chains with less than 20 k on them like you describe, tight then loose. Maybe to just find that sweet spot with the manual tensioner setting helps. The manual tensioner is many times just overlooked as a maintenance item.
Glad you found it. Would be a pain to get back into the engine after all that work.
Safe riding
Old Sep 2, 2016 | 10:00 AM
0maha's Avatar
0maha
My primary chain threw a link at 20k miles. I was surprised at how much smoother the replacement chain (I went with Diamond) runs.
I would have never thought to replace it if the link hadn't come out with the oil during a fluid change. I'm glad I did. The difference on mine was definitely noticeable.
Old Sep 2, 2016 | 11:05 AM
Plumbwader's Avatar
Plumbwader
Thanks for that.
I was working on this with my friend at a local Indy shop with the owners guidance. He said it is uncommon for a well maintained chain to be toast at 40k, but not uncommon if it isnt adjusted at regular intervals. I have learned so much about my bike in the last couple of weeks its crazy. I will definitely not hesitate to check and make adjustments when necessary.
Old Sep 4, 2016 | 04:29 PM
carlgrover's Avatar
carlgrover
the original post said the primary chain was adjusted to 1/2". That's a little snug for that bike. I believe the spec is much looser than that. About 3/4", I think. You might want to keep an eye on that new chain to see if it starts making the same noise in the future. I would also watch the primary chain adjusting shoe for abnormal wear.
carl
Old Sep 4, 2016 | 04:32 PM
texashillcountry
Dirt don't hurt
carl
Cold spec is 5/8ths" to 7/8ths".
Hot is 3/8ths" to 5/8ths".
kbatrph
EVO
Jun 4, 2018 10:56 AM
cajun1957a
Aug 9, 2017 09:32 PM
xwhyz1959
Aug 3, 2013 07:15 AM
faber
Mar 7, 2010 01:13 AM
wydglydrydr
Feb 13, 2009 07:26 AM
