Could it be a bad primary chain
Old Sep 1, 2016 | 06:32 AM
Plumbwader's Avatar
Plumbwader
Default Could it be a bad primary chain
Ok, so 1998 Ultra Classic, I decked the heads .050 added an EV 27 cam, hydraulic lifters, adj. pushrods, ripped out the EFI and put on a Mikuni HSR 42. It runs like a scalded ape, however, it has a clack, clack, clack sound when its running kind of like bad gas pinging. I put it under load, i.e. I held the front brake and let out the clutch slowly and the noise got quieter. I checked the play in the primary chain and it has some tight spots and some loose spots and its adjusted to about 1/2" at its tightest spot. Im so ready to ride this thing but the clacking sound really has me frustrated and worried. BTW 40,000 miles on the counter.
Old Sep 1, 2016 | 07:23 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
The first step is to localize the sound.
Are you sure it's coming out of the primary??
Old Sep 1, 2016 | 08:03 AM
Plumbwader's Avatar
Plumbwader
Fairly certain. We put it under load and it quieted down significantly. We are going to take it apart tonight. The only other thing I can think is possibly bad rockers? Its about the only thing that didnt get addressed in the top end.
Old Sep 1, 2016 | 08:20 AM
IBDAGRIZ's Avatar
IBDAGRIZ
You can pick up a mechanics stethoscope at most auto parts joints for about $20. Really helps on noise locations.
Griz
Uncle G.'s Avatar
Uncle G.
I'd be sure the noise is coming from the motor/primary. I've had noises like that turn out to be a loose footboard or loose shift linkage.
Old Sep 1, 2016 | 08:29 AM
texashillcountry
Dirt don't hurt
There is a lot of distance between the rocker boxes and the primary.
That is why I said the first step is to localize the sound.
It could be something as simple as adding a couple of flats to your pushrod adjustment.
FWIW the tightest part of your primary chain should be no tighter than 5/8th" cold and 3/8th" hot according to the book.
Old Sep 1, 2016 | 08:30 AM
98hotrodfatboy's Avatar
98hotrodfatboy
What did you preload the lifters to and what is the idle rpm?
I doubt you have any abnormal wear at the rockers. Oem rockers are good for 100k.
Old Sep 1, 2016 | 08:33 AM
Plumbwader's Avatar
Plumbwader
Im not sure what you mean by lifter preload. Idle rpm is about 1000
Old Sep 1, 2016 | 08:36 AM
Super Glidester's Avatar
Super Glidester
How bout the cam chest? Twinkie tensioners maybe?
Wait its a 98, my bad its EVO isn't it?
Old Sep 1, 2016 | 08:38 AM
98hotrodfatboy
You said you put adjustable pushrods in. How many flats did you lengthen the pushrods from zero lash? Load the lifters....
Your clack could also be a bad Compensator. They are know to get noisy. You obviously have the fsm right?
