Third gear grind
Old Oct 3, 2016 | 02:21 PM
Carmell RKC's Avatar
Carmell RKC
Default Third gear grind
Hi All,
Had a question for you all, tried a search but it didn't yield any results. My recently purchased 99 FXR2 has a slight grinding sensation in the shift lever when shifting from second to third. The grind is not audible and is only obvious if the engine RPM is around 3K or higher. If I'm just taking it easy and shifting below 3K RPM, I don't notice it. Third gear is the only one that does it. It does not grind when downshifting. I tried adjusting the clutch push rod and lever free play but it had no affect. I thought about changing the trans gear oil to Redline Shockproof Heavy to see if I can minimize it. I have no idea what is in the tranny right now but I do know it was dealer serviced recently. Any thoughts would be appreciated, thanks !
Old Oct 3, 2016 | 02:58 PM
grbrown's Avatar
grbrown
Er - change gear more quickly?!
Joking aside, when changing gear we only need a token operation of the clutch lever, so adjustment shouldn't be an issue. I do indeed change gear quickly, but that is something I've practiced for decades, on a wide variety of bikes. I take the slack out of the gear lever before operating the clutch and shifting, simultaneously. Doesn't give the darned thing much chance to grind!
Old Oct 3, 2016 | 09:27 PM
0maha's Avatar
0maha
Yes, that's it.
I've had bikes that were more finicky than others, but they all seemed to respond well to a bit of pre- loading on the shifter.
Old Oct 3, 2016 | 10:26 PM
Carmell RKC
Cool thanks guys, I'll give that a try.
Old Oct 4, 2016 | 10:54 AM
corliss@bakerdrivetrain.com's Avatar
It's shot, you should sell it, I will give you fair market value. You can reach me at 517-339-3835.
If you decide to keep it try above advice and then report back.
SixDD
May 10, 2019 06:08 AM
brandnew
2014-2024 Touring Models
Jul 26, 2017 11:54 AM
Johnny Glide
14
Jul 11, 2015 12:59 PM
MrPeepers
Jul 14, 2013 07:00 PM
hotrod351
May 12, 2009 09:46 PM
