FXSTSB - Some wiring help
Old Oct 12, 2016 | 11:05 PM
aenemated's Avatar
aenemated
Default FXSTSB - Some wiring help
(Sorry for the cross post - initially dropped this in the Softail forum)
Howdy yall - been a good minute since I've been around here.
I picked up one of them Softail Bad Boys from the mid 90s (I think they only ran from 95-97) a couple months ago. She was in pretty good shape, lowish miles for a 20 y/o bike.
I wasn't a huge fan of a lot of the work done over the years, so after mulling over it a week or two, I started a pretty major overhaul on pretty much the whole thing.
When I got to replacing the bars - I found the old wiring was in terrible shape. A lot had just been chopped off and taped up so I decided to start fresh with a nice new wiring harness - I was replacing everything up top anyway. Found one on eBay with factory matching wire colors and it's really 90% there. But I've got some issues with my rear blinkers. Decided not to clutter up that pretty frontend with front blinkers so it's only the rear.
I've attached some pics of the current situation - which I just crudely twisted together for testing before I pretty all that up. Headlight Hi/Lo works fine, On/Off works fine, starter works fine, most on the dash works fine (N, On, Hi-Beams, Left arrow), tail lamp lights up, brightens for front and rear brakes. The problem is ... when I switch on from the dash switch; only the right side tail lamp lights up. When I hight the right blinker - nothing happens at all. However, if I hit the left blinker - it blinks and the left arrow on the dash comes on.
I've read a bit that this is a fairly common wiring mistake but I couldn't find much direction of where to go. Everything from my new harness to the guides I kept from the old are lined up - but I've got a couple wires left hanging free that I'm pretty sure are the colors for the rear blinkers.
So I was hoping one of you kind fellas could point me in the right direction as to what I've screwed up. Pics attached show current state on left and right as well as the couple strays hanging.
Attached Thumbnails FXSTSB - Some wiring help-img_3868.jpg   FXSTSB - Some wiring help-img_3869.jpg   FXSTSB - Some wiring help-img_3870.jpg
Old Oct 12, 2016 | 11:06 PM
aenemated's Avatar
aenemated
Also, for any curious - here's the project so far; before and currently.
Attached Thumbnails FXSTSB - Some wiring help-img_3723.jpg   FXSTSB - Some wiring help-img_3854.jpg
Old Oct 13, 2016 | 06:15 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Make sure your getting power from the turn signal switch to the turn signal module. With both the dash indicator and rear blinker not working I would think they are not getting voltage. On my 98 it's the w/bn wire coming from the turn signal switch to the module@pin 7. Coming out of the module it's pin 3 brown. Either there's no power from o/w to the turn switch or to the module (w/bn) or to the lamp circuit on the brown wire or the grounds are no good or you have a open circuit coming out of the module on the brown wire. recheck all connections..........
Old Oct 14, 2016 | 01:11 AM
aenemated's Avatar
aenemated
Thanks man! I think you're right. Finally tracked down a service manual and I believe I've found the problem.
And ... duh, the hanging wiring would otherwise be routed to the front blinkers; which I didn't bother with.
(High five for the red, btw)
aenemated
Oct 13, 2016 03:05 PM
marbee40
Shovelhead
Aug 19, 2014 11:32 PM
blair
Apr 7, 2013 11:48 AM
capttxrngr
Apr 8, 2012 04:49 PM
Radman89
Aug 16, 2008 01:51 AM
