Winter storage?
Old Oct 21, 2016 | 10:55 AM
IRON1250's Avatar
IRON1250
Default Winter storage?
This will be the first winter in a long time I have stored a carb bike. Do you like to shut off the fuel and run the carb dry or leave fuel in the carb. Of course stabilizer will be used.
Old Oct 21, 2016 | 12:13 PM
Hackd's Avatar
Hackd
Don't do anything special to mine over the winter. I used to do the whole shebang. Fogged the cylinders, etc. I don't use StaBil any longer, after having it gum up my carburetor to the point the bike wouldn't run.
Now I just put fresh oil in all the holes, top off the gas tank with fresh fuel adding some SeaFoam to it to appease the gods. Fire the bike up and let it run for a bit to get some of the elixir down into the carb bowl. Shut it down, turn off the petcock, pull the battery out and put on the tender, cover the bike when it cools down, and put it to sleep until spring.
Old Oct 21, 2016 | 12:14 PM
soft 02's Avatar
soft 02
What is winter? Its was 92* yesterday.
Old Oct 21, 2016 | 12:21 PM
traildog's Avatar
traildog
Thank you......
Old Oct 21, 2016 | 12:24 PM
langwilliams's Avatar
langwilliams
I just fill it up with 93 an shut the fuel off an run it dry...I'll change the oil in spring before riding, the oil in it has less than 1K on it.
Old Oct 21, 2016 | 12:32 PM
Hackd's Avatar
Hackd
Originally Posted by traildog
Thank you......
You're welcome.... Royalty check is in the mail....
Old Oct 22, 2016 | 07:30 AM
traildog's Avatar
traildog
Old Oct 22, 2016 | 07:33 AM
YeOldeStonecat's Avatar
YeOldeStonecat
I still squeeze in rides throughout the winter, so long as it's not below 20*F, but I still do the basics before winter.
*Change the oil in all 3 holes
*I'll run the carb dry. Doubt it will be an issue with the mikuni carb on my current ride, but my prior ride had an S&S super E...and they were known to leak. Only reason I ran it dry...was so it wouldn't steadily drip out the bowl and stink up the garage.
For the past couple of decades, gas from the big brand stations comes with enough perservatives 'n anti H2O in them so I stopped using seafoam/stabil stuff back in the...oh..late 80's I think. Won't do any harm using it...but the fact that all my engines (tons of yard equipment, boat motors, bikes, etc) start up just fine each spring is proof that whatever the fuel suppliers put in the fuel now works.
Old Oct 22, 2016 | 09:06 AM
touchdown's Avatar
touchdown
Just ride the dame thing
Chaz127
Oct 25, 2018 12:09 PM
MJHJEA
EVO
19
Nov 16, 2014 03:00 PM
mark10
Dec 22, 2011 09:36 PM
MidnitEvil
Feb 20, 2011 12:51 AM
gels55
Nov 16, 2007 08:43 AM
