Cam ID
Old Oct 22, 2016 | 04:37 PM
Carmell RKC's Avatar
Carmell RKC
Default Cam ID
Started my cam swap this morning. Im not sure what the manufacturer or spec of the cam I took out is, and the only markings are what is shown on the lobes. The only thing I could think of was a Sifton 143 ? Anyone have any ideas ?
Not that it matters much as Im swapping in the tried and true EV27. The 143 cam seemed to come on really hard around 3000 RPMs on up.
Old Oct 22, 2016 | 11:54 PM
langwilliams's Avatar
langwilliams
sifton 143?
http://www.nightrider.com/biketech/HDMasterCamSpecs.pdf
Old Oct 23, 2016 | 02:57 AM
gusotto's Avatar
gusotto
Nice chart but I didn't see the SE255 cam listed.
Old Oct 23, 2016 | 07:14 AM
Prot's Avatar
Prot
While that is true, it doesn't matter because SE255 is a TC cam shaft and this is the Evo section. SE255 is probably not there because it is a newer cam than the chart.
Old Oct 23, 2016 | 11:34 AM
langwilliams
everyone says you can't go wrong with the 27...I have the ev 3010 which has similar stats an I love it. I wasn't concerned with peak HP/Tq numbers, I wanted the improvement where I ride: 2000-4500 rpm
Old Oct 24, 2016 | 08:52 AM
98hotrodfatboy's Avatar
98hotrodfatboy
To get a better idea of what you took out measure the total height of the lobe then the base circle and subtract the bar circle from the total lobe height and multiply by 1.625 and that will give you total lift as indicated by most cam manufacturers. Then go to the site Langwillians suggested tho match it up. Looks like that cam has a nice duration.
johnwesley
Engine Mechanical Topics
Feb 11, 2018 12:30 AM
94 ultra
2014-2024 Touring Models
Oct 23, 2016 08:44 PM
hoppynwv
Exhaust System Topics
Jun 24, 2010 09:13 AM
steadyflow
Oct 11, 2007 07:47 AM
gobby
Harley Davidson Videos
May 5, 2006 01:27 PM
