Rear Cylinder Noise - EVO
Old Oct 31, 2016 | 09:14 PM
JesseDyna's Avatar
JesseDyna
Default Rear Cylinder Noise - EVO
I have this annoying noise which I've isolated to the rear cylinder. Both front and rear spark plugs are a nice tan. The primary belt is adjusted so it's not that.
It seems like a breathing sound rather than a grinding or ticking sound.
I've attached a .wav file so you can hear. The sound is exaggerated in the recording. The motor overall sounds ok other than this sound which has appeared over a few hundred miles of driving.
In the attached file, in the moments when you don't hear that predominant chugging sound, it's when I move the mic away from the rear cylinder. This sound is louder on the side opposite the carb.
Any ideas on this? Thanks for any help.
File Type: wav
Old Oct 31, 2016 | 09:47 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Do a compression check.
Old Oct 31, 2016 | 09:59 PM
cardboard's Avatar
cardboard
And checked to see if you have a Exhaust leak ?
Old Oct 31, 2016 | 10:12 PM
JesseDyna's Avatar
JesseDyna
Compression 140 rear, 130 front. So the rear is actually better.
I will check for exhaust leak. It runs just fine. I've been going through a saga of a leaky carb which turned out to be a hairline crack in the fuel inlet which is now fixed. I'd think that if it were an exhause leak it would be louder on the exhaust side of the engine but I'll check it out.
Old Oct 31, 2016 | 10:24 PM
cardboard's Avatar
cardboard
You can go to Harbor freight and get a Stethoscope that might help.
http://www.harborfreight.com/mechani...ope-69913.html
Old Oct 31, 2016 | 11:11 PM
JesseDyna's Avatar
JesseDyna
There's been so much going on with this bike it may have been there all along and I just didn't notice but it seems to have arisen during the past couple days (including a 200 mile ride).
I've been using a steth for more years than I want to admit - a stethoscope check reveals the same noise in both valve covers - ie, nothing unusual. The only thing I can say is that it's from the rear cylinder, and more prominent on the driver side. Interestingly I can hear the sound without the steth but I don't hear that sound amplified in any part that I've tried to listen to.
I did an exhaust leak check with a rather smokey incense stick and no leaks discernible. I also checked around the valve covers to be sure.
One thing is odd - I check the plug wires and I don't get any reading other than infinity for resistance. They do look pretty bad and they have this Kuryakin lighting device on them. Unfortunately I don't have a good wire to check. Long shot but maybe a weak spark? The plugs look aces!
I'd be very happy if this was the normal Harley cacophony but I'm all ears for any ideas.
Old Nov 1, 2016 | 12:06 AM
Prot's Avatar
Prot
Although not the problem, that compression seems kind of low.
How is the breather system setup? What year is it?
I don't think it is your spark plug wires although a new set is rather cheap.
Old Nov 1, 2016 | 12:47 AM
JesseDyna's Avatar
JesseDyna
1995. That was a quick and dirty compression test but I forgot to open the throttle. That was with the engine warm but not hot. Air filter on.
Breather setup - has a K&N air filter with the horseshoe breather tube on the head breather ports that descends in a hose to the base of the bike.
Old Nov 1, 2016 | 01:20 AM
unnnivers's Avatar
unnnivers
I was worried about identical noise of my 1996 ultra. But I noticed that sound after replacing an air cleaner to K&N. After all tests everything is o.k., only that chugging noize which is a simple intake breath of motor. Keep calm, engine is o.k.
My thread: https://www.hdforums.com/forum/evo-c...it-normal.html
Old Nov 1, 2016 | 06:17 AM
98hotrodfatboy's Avatar
98hotrodfatboy
For one thing the idle sounds a little low and what cam do you have in it? Kinda sounds normal to me......
