thanks guys, main problem probably the autozone battery, was broke when the hd battery died so got what i could get. Probably gonna buy a no name 1.4kw starter and a agm battery, put the jumpimg to ride nonsense behind me. Mainly was concerned if the no name starters were ok
My suggestion is try the battery first and see what that does for you.
It's way easier to change a battery than a starter.
Not to mention adding the cost of a possibly unnecessary starter and fluids and gaskets.
I'd install the battery and grab a volt meter and see what it tells me before I bought a starter.
blew the starter drive within 6mon, allballz replaced under warranty (go them!)
not wanting to miss the already short riding season, i threw the stock 1.2 starter in
been 2.5 years now....the stock 1.2 spins over my 11:1CR 124" with little to no struggle as long as the battery aint dead. hot-starts are another story (dead stall if i catch it wrong). I'll keep an eye on this thread - got a "batteries+" battery 3 years ago....havent killed it yet....but it dies FAST if i aint riding every day...and im not great about keeping it on a tender. Been lookin hard at the lithium versions
my main bitch has been cold weather starts, the tp121 is a lil bitchy to fire under 50 degrees outside, usually have to adjust the idle mixture, and the battery just wont hold up even using comp releases, it maybe just a battery thing, what is the best high cca battery i could get? btw i keep my battery on a tender all the time, thinking the cheapo battery just doesnt have the bal*s for the cold start, it starts fine the rest of the day, just not on cold mornings
USA-Made Big Crank ETX30L 400 Battery $109.00, All ***** 1.4 starter, big cables. Starts the monster but broke the starter drive 2 years ago so not invincible, battery finished it's third season and still strong
Thats a big battery and definitely won't fit in my fatboy....
