Besides the axle size, it's the caliper mounts that identify it as 2000-2013.
FWIW, you can put those 2000-13 sliders on your tubes...the sliders are cheap.
I would be ok with the caliper size being different, I could put the new ones on. Just curious about the upper portion if it would slide into my triple tree?
Yes, those ebay units will work and if you get them them cheap...great, but if not, just powder some takeoffs and install yourself...you can handle it
you'll want those 2000-later caliper mounts for the Brembos you are going to use with the 11.8"(300mm) rotors on the Enforcer
Thank you that's what I was thinking, I was looking at the rotors on the enforcer and noticed they are a different size then the Electra glide ones. So I'll just get the black sliders, no need for the whole thing like in the eBay ad correct?
Correct...but again, if they happen to go cheap, that would save you effort and rebuild kit costs.
Also you might start thinking about calipers (master cyl?) and an axle...
06-later VRod or 08-later Touring OE Brembos (same caliper).
You might want the Brembo master cylinder also, but you would need the clutch side also if you want the levers to match. That also means you would need the 96-07 switch housings (has provisions for throttle cables).
Your 95-earlier Master may work OK though
You you'll want a 08-later touring 25mm axle and spacers
Damn, one thing always leads to another. I would like to stay away from changing the master cylinder and switches and all that. Wiring is not my strong point, in fact I down right suck at it. Not sure what it is about it but it just doesn't click in my head.
So if I went with the brembo calipers I could use the old stock master still, correct? Just won't have abs without the newer master cylinder I'm guessing?
I will get the axle for sure once I get the new fork sliders.
