So the tear down starts...
More good work
Coming from a 1-1/2" belt, you'll probably think any of the later belts are "Thin".
FWIW, the incoming pulley will be for a 1" belt and 68-tooth if using OEM specs for those IDS "Cush Drive" pulley. Your original pulley was 70 tooth. You'll know more about belt alignment when you get the pulley in place. Probably won't be a big deal.
But more importantly...is that Pinto Wagon
More good work
Thanks! Yes the pulley coming is a 68 tooth, do you think it will make much difference in anything? I was thinking if anything it will lower the rpms slightly if I'm thinking correctly. Thinking a 20mm belt will do the trick but we will see.
Yes that is my pinto wagon. I've had it since I was 14 and I'm turning 40 in March so she's been around a long time! I have a 302 in it, 4 speed toplaoder and an 8" rear end which is currently destroyed. I'm thinking about putting an explorer 8.8 with a limited slip in it. I've got 17" Cobra mustang wheels in it. Fun little ride!
thanks! I'll look into the primary offset kit. Did a little checking into it, I couldn't come up with anything with all the googling I was doing just had the wording wrong. If I go with a 20mm belt I'm hoping it will work. Also thought about going with a chain but can't find a kit that will fit the enforcer wheel. May have to make some more custom stuff.
Here's a few...
http://www.dragosbikeworks.com/chain-drives.html
"Drago's Bike Works IDs chain drives for 2008 and newer baggers."
http://www.zippersperformance.com/ch...fl-models.html
RB Racing used to make a rear sprocket, but I don't see it now listed. Also some info here on swingarms
http://www.rbracing-rsr.com/
http://www.rbracing-rsr.com/swingarm.html
BIG Thumbs up on the Pinto
Here's a few...
BIG Thumbs ups on the Pinto
