The best I could figure was the SP3 it for the 94/95 FLT's. in 94 they did not have the Attitude switch. It was introduced in 95 and if you look at Ronnies on-line fiche it will show the same sensor with attitude that also fits my 98 Fatboy. They also show the pre 95 sensor which is the 32400-80abut was superseded by the 32400-94. the 32448-95a was the upgraded sensor with the Attitude switch. So i think the Standard Motor Products switch SP3 is the one for 95-99 Evo's I will try it and let you know. Man if it is it will save a lot of deniero's.
I purchased the Standard Motor Products MC-SPA3 off of Amazon for $38.55 and should be here this week. I will take picture and document it for the forum. I have a 1998 FLHR (carburetor)
I believe the only difference between MC-SPA1/2/3 is the terminations.
SPA3 is male, SPA2 is 2 female, 1 male and SPA1 is all female.
There are 2 different sensors for the EVO. One is for the carb bikes and the other for EFI bikes. I do not think they can be interchanged.
There is no problem swapping out a non-attitude plate for one without. IM and I discussed this a month ago on this very thread. I replaced mine in my 98RK with EFI with a Standard motor products one.
Take a look at the pins when ordering as they differ between the 3 styles. You can always fix any incorrect ordering buy using your old wiring if needed at the connections. Did that before and just cut off the old ends and soldered onto the new sensor plate wiring.
Quick Update: Bike has been checked over thoroughly at the shop, adjusted and ready for riding season, it's running great and strong so I'm not going to tinker with that at all. Thanks for all the great info guys!
