View Poll Results: What method works the best ?
Drilling and using a roll pins
7.14%
Emery cloth
7.14%
Aluminum strips
7.14%
Rubber strips
0%
Drill the top plate and use a set screws
14.29%
Other method
64.29%
Voters: 14. You may not vote on this poll
Locking down ape hangers
Old Feb 21, 2017 | 06:56 PM
Panheader's Avatar
Panheader
I slathered red locktite gel on the knurled section and havent had any problems since.
Old Feb 22, 2017 | 04:18 AM
Yankee Dog's Avatar
Yankee Dog
Drywall sanding screen at home depot. Tear a strip off and wrap at the knurling. It is thicker than the beer can shim but will compress. Yd
Old Oct 5, 2024 | 09:30 AM
89FLHT's Avatar
89FLHT
Know this thread is a little older, but the drywall sanding screen was something that I had on the shelf and it worked well. Thanks Yankee Dog ! I have Nash 14" apes on HD 6" spinger risers. The bars are knurled , but the risers are not. The Sanding screen did compress and helps get a better bite on it.
Old Oct 5, 2024 | 09:34 AM
blackjeep's Avatar
blackjeep
Center punch both the risers and the bars in multiple locations where they contact. Works a charm for every set i’v done and i’v done alot!
Old Oct 6, 2024 | 09:38 PM
Spanners39's Avatar
Spanners39
Tighten the top clamp bolts until they break and then back off 1/4 turn...
Old Oct 6, 2024 | 11:36 PM
brakeless's Avatar
brakeless
I also have been using the center punch method for decades with excellent results.
Old Oct 7, 2024 | 03:59 AM
RANGER73's Avatar
RANGER73
I bought the top clamp with the set screws for my 14's.
Old Oct 8, 2024 | 06:51 AM
Bubba Zanetti's Avatar
Bubba Zanetti
I just saw that this is an old thread but I'll reply anyway for anyone who stumbles in here in the future.
I put some taller bars on my Road King and they started to slip on me. So I scored the inside of the risers with a Dremel. I just cut 5 or 6 shallow lines across the bottom and top of each riser where the knurling of the bars would meet up with it.
I also placed some homemade beer can shims in there for good measure, and never had a slip the entire time after I did it. I think you could get away without the shims though.
Old Oct 9, 2024 | 02:11 AM
TwiZted Biker's Avatar
TwiZted Biker
Plumbers crocus cloth for cleaning copper pipe, shims and holds them solid. Done a lot, bike I just picked up needs it too.
Old Oct 13, 2024 | 10:14 AM
89FLHT's Avatar
89FLHT
Took the bike out and they loosened up again. Plus, the 28 year old risers had 1 bolt that was almost stripped and the others were not far behind. Installed 4 Time Serts and got busy with a hammer and punch to dimple the risers and the caps. Much better now.
