Exhausted....
Old Mar 18, 2017 | 07:53 AM
  #51
Hackd's Avatar
Hackd
Originally Posted by Schex3x
Hack, you probably needed to make a longer installer by grinding the end of a bolt to engage the tang of the heli-coil, I've installed them holes 2" deep, not wanting to disassemble what I was working on.
The installation tool was long enough. I think the problem was my reluctance to drill deeper. Which meant (as you know), I couldn't tap for the helicoil deeper. Probably the reason I had to use a 1" fastener, rather than the 1.25" one, because the installed helicoil thread didn't align with any of the remaining original threads in the case.
As I posted in the other thread, I'm done messing with it, and the Thunderheader will be going on the bike in a couple of days (going to wait for the hylomar to set up before putting any oil in the trans).
Old Mar 18, 2017 | 01:20 PM
  #52
LowriderHarold's Avatar
LowriderHarold
Default Rue of thumb
Standard rule of thumb, Internal threads are 1.5 x diameter of said fastener.
(Example)
For a .250 bolt, you need , at a minimum of .375 length of threads.
Any more , is just a waste.
Ride Safe,
Harold
Old Mar 18, 2017 | 03:46 PM
  #53
Hackd's Avatar
Hackd
Thanks.
It's a 5/16-18 fastener, so my martini affected math equates that to 15/32" of thread. Definitely don't thing the area where the fastener goes in is that thick. Maybe a tad over .375"?
Either way, I'm not tearing into the transmission this year. Which would be the ultimate 'fix' for the problem. As long as it is nothing more than a minor seepage, I'm going to live with it, until the trans takes a dump (highly unlikely)...
Old Mar 19, 2017 | 08:43 AM
  #54
Hackd's Avatar
Hackd
Okay, I've scoured my 1993 FSM, and I cannot for the life of me find any reference to the torque spec for the headpipe flanges. A good amount of internet searching doesn't seem to come up with a definitive value.
Would 10-15 lb/ft be correct? Or what? Gutentite???
Old Mar 19, 2017 | 11:46 AM
  #55
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
If you're talking about where the exhaust bolts to the head my book says 60-80 inlbs.
I usually just use the gutentite setting.
Old Mar 19, 2017 | 12:15 PM
  #56
Hackd's Avatar
Hackd
Yeah, where the flanges attach to the heads. From all I could glean off the internet, it was 96-120 in/lbs. Just surprised that the FSM didn't have any reference to it. I'll tighten them to 75 in/lbs and go from there.
Old Mar 19, 2017 | 01:55 PM
  #57
Hackd's Avatar
Hackd
Default On....
Got it all on. The Kuryakan floorboard spacers are a definite necessity. Heat shields were a real puzzle. I'm still a bit uncertain about the one from the rear cylinder, but it's ON!
On to the next repair: Handlebar replacement...
Old Mar 19, 2017 | 02:08 PM
  #58
Beemervet's Avatar
Beemervet
Did you start it up yet?
Old Mar 19, 2017 | 02:26 PM
  #59
LowriderHarold
[QUOTE=Hackd;16045983]Name:  20170319_144130_zpsc8eeypmi.jpg
Got it all on. The Kuryakan floorboard spacers are a definite necessity. Heat shields were a real puzzle. I'm still a bit uncertain about the one from the rear cylinder, but it's ON!QUOTE]
Looks good! Need a video with sound!
Ride Safe,
harold
Old Mar 19, 2017 | 04:08 PM
  #60
texashillcountry
Dirt don't hurt
I found the torque specs for mine in chapter 4.
