adding oil pressure gauge to FXRS
My question is, has anyone done this, how has it turned out and what gauge and connectors did you use?
Thanks!
If you don't want to pull your hair out for no reason don't install an oil pressure gauge.
As long as the oil light goes out you are fine.
OK man, I got it! NO oil pressure gauge.
Cars have "shell" bearings (also called "journal" bearings) operate "hydrodynamicaly"": They depend on a steady amount of oil pressure and viscosity to keep them "afloat" and prevent metal-to-metal contact. No/low pressure = bearings rub = expensive problems.
Harley motors are all roller bearings. Like this:
The silver cages on the left are for the crank pin bearings. (The bearings themselves are in the bag.) They sit between your connecting rods and the crank pin.
The bearing on the right (with the black cage) sit on the pinion shaft on the right side of the motor. They are straight roller bearings (meaning they allow the crankshaft to move axially).
Behind that bearing are the tapered roller bearings and their corresponding races. Those are pressed on to spline side of the crank (left side of the motor), one on either side of the left side case. In that way, they position the crankshaft axially (side to side).
Anyway, what all this means is that it's roller bearings all through the business end of the motor. Those bearings do not require any pressure to operate. All they need is a steady flow of oil to keep them lubricated and cool.
The bottom line to all of this is that if your oil pressure warning light isn't coming on, you're fine. A pressure gauge (which my Electra Glide, unfortunately, came with from the factory) doesn't do anything for you other than turn something you can ignore into something you will worry about.
excellent! Thanks 0maha
As long as the oil light goes out above idle, you are fine.
True mate
