Ignition Wiring Question
Old Apr 13, 2017 | 01:18 PM
ezridermn's Avatar
ezridermn
Default Ignition Wiring Question
I am rebuilding a 1984 Harley FXRT. I completely disassembled the bike and am now putting it back together. I installed a new ignition system and now need to route the ignition wires over to the coil.
It is not obvious to me what the best way to do it is. Is it to run wires under the gas tank between the cylinders? Or along the right side of the frame and then up and over the transmission? Or some other way that is not obvious to me.
I would appreciate any suggestions you are willing to offer up. Thanks in advance for your help.
Old Apr 13, 2017 | 05:34 PM
row jimmie's Avatar
row jimmie
If you mean out of the cam cover I'd run under in between tranny and motor come up by inner primary up to coil, that is if the coil is in the same place as 96 narrow glide, where is the coil, how we're they originally.
Old Apr 14, 2017 | 07:54 AM
ezridermn's Avatar
ezridermn
The coil is on the left side centered between the cylinders. See the attached picture. Thanks for taking the time to respond!
Old Apr 14, 2017 | 01:58 PM
row jimmie's Avatar
row jimmie
I think I would see if you could go under, up through the gap between the motor and tranny to the backbone come in from the backside under tank to coil. If you can zip tie it to the fame or whatever on the way up try to hide it if possible. Good luck you putting on a hi 4N ignition?
Old Apr 17, 2017 | 04:46 AM
GraemeR's Avatar
GraemeR
I did the same job. Ran them from the module under the bike to the right side panel (thats where I put the connector) and then through where the battery sits and then hugging the top frame and then dropping down to the coils.
Wcm71
Ironhead
Nov 3, 2014 04:53 AM
outfishin35
Aug 1, 2013 06:54 AM
ncottrell2009
Ironhead
Oct 18, 2012 02:06 PM
tymatt67
Sep 23, 2012 08:54 AM
kick it
Shovelhead
Sep 25, 2008 02:01 PM
