Leak Down Question
Old Apr 27, 2017 | 08:44 AM
  #31
aces&8s's Avatar
aces&8s
Originally Posted by daven9113
Does the exhaust pop on decel? Does the carb spit or backfire? Just making sure you eliminated an exhaust leak.
I know you checked for an intake leak with carb cleaner, but what you describe sounds like an intake manifold leak. I would check, or maybe just replace gaskets, and check condition of manifold. Good luck.
Carb does not back fire and no leaks. It just misses at idle when hot.
Old Apr 28, 2017 | 07:15 PM
  #32
aces&8s's Avatar
aces&8s
OK all,, I ran out of things to change out so I installed new intake seals and not just no but hell no it still not fixed. I am really loosing faith.
Problem: Does not want to idle and rear cyl exhaust makes a FLUFF, FLUFF sound after QUICK throttle TWIST. Take it off idle and run thru the gears it's a rocket.. WHAT UP???
Old Apr 28, 2017 | 07:19 PM
  #33
aces&8s's Avatar
aces&8s
How much sea foam do you add to 5 gal tank?
Old Apr 28, 2017 | 07:56 PM
  #34
Dr.Hess's Avatar
Dr.Hess
A half a bottle. A full bottle (pint?) treats about 10 gallons.
Old Apr 28, 2017 | 08:13 PM
  #35
aces&8s's Avatar
aces&8s
When I changed the intake seals the ports looked pretty clean. My thought was possibly a sticky valve and sea foam. BUT my compression check on both cyl were dead exact 208 lb. dang if I know.
My wife agreed the FLUFF sound was from rear cyl exhaust..??
Old Apr 28, 2017 | 08:23 PM
  #36
Dr.Hess's Avatar
Dr.Hess
Is there an exhaust leak? That can make some strange sounds. With the motor idling, try blowing some smoke around the exhaust pipes up near the head. See if the smoke moves in unexpected ways.
Old Apr 28, 2017 | 08:31 PM
  #37
aces&8s's Avatar
aces&8s
tomorrow I will do the rear exhaust gasket
Old Apr 28, 2017 | 08:32 PM
  #38
aces&8s's Avatar
aces&8s
Ill try it.
Old Apr 28, 2017 | 08:55 PM
  #39
aces&8s's Avatar
aces&8s
I lit a Cuban cigar and blew the smoke up around the exhaust , kinda looked like the smoke on one side was blowing away but had to run to the bath rm to puke up my supper from the cigar, Geesh.
Ill try a new ex gasket tomorrow if I live thru the nite.
Old Apr 28, 2017 | 09:24 PM
  #40
Tony_N's Avatar
Tony_N
You're not supposed to inhale them Herb!
