Leak Down Question
Old May 1, 2017 | 04:11 PM
  #71
aces&8s's Avatar
aces&8s
The cheapest way to go.
  #72
aces&8s's Avatar
aces&8s
Old May 1, 2017 | 05:21 PM
  #73
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
You better hope you're not a deep sleeper!!!!!
Old May 1, 2017 | 08:16 PM
  #74
aces&8s's Avatar
aces&8s
That's the wife's car, incentive to go to work. She luvs me for convenience.
Old May 2, 2017 | 08:10 AM
  #75
Schex's Avatar
Schex
Thanks Doc, What ever this Engine may need it is one great running Evo. All most positive it's a slightly bent rear intake that's making it hard to seal up. Im ordering a new intake Monday and that should cure the rear cyl fluff and idle
You have a compression tester, you can check for leaking valves without a leakdown tester.
Use the hose from the compression tester, remove the schrader valve from the end that screws into the head, regulate your shop air down around 100psi,
Screw the hose in the cylinder your going to check.
Shift the bike into high gear, 5th or 6th, whatevers in there, rotate the tire while feeling for air blowing out the hose until it stops and starts sucking, back it up a little, your now around TDC.
Get a helper to hold the rear brake, or strap the brake pedal down tight, rear wheel off the ground.
Plug the shop air into the hose in the head and listen for air coming from intake and exhaust, should be very little to none.
Air will be coming from the engine breather past the rings, just wont know how much, but We're really just checking valves here.
Now, if you hear air getting past any valves, unplug the shop air, loosen the adjustable pushrods for that cylinder so the valves can't open, and plug in the shop air and test again, you don't really have to hold the brake as valves will be closed regardless of cam position.
If it leaked, then stopped after you loosened the pushrods, either there's a lifter problem, or the engine simply wasn't at TDC, or rolled over and opened a valve during the first test.
Old May 5, 2017 | 04:37 PM
  #76
aces&8s's Avatar
aces&8s
I fixed it.... I chased my tail for 2 weeks and kept going back to an intake leak. Last night I changed my intake seal for the 2nd time and I noticed a very small crack in the rubber boot covering my VOES port on the carb. I said earlier " It's something small " I'm not seeing. Bumped the start and ran Perfect. Wanted to thank all 2 people that at least tried to help.
Old May 5, 2017 | 05:55 PM
  #77
texashillcountry
Dirt don't hurt
So now that you have your motor fixed you still gonna get the 111????
Old May 5, 2017 | 06:42 PM
  #78
aces&8s's Avatar
aces&8s
Yes of coarse.
Old May 5, 2017 | 07:13 PM
  #79
br549A1's Avatar
br549A1
Guess I better get that $6 ready
Old May 5, 2017 | 07:24 PM
  #80
aces&8s's Avatar
aces&8s
Don't forget shipping.
