Evo Softail ticking/clattering noise
Old Sep 27, 2017 | 05:17 AM
  #31
Evoken's Avatar
Evoken
Malo,
If you have never been inside of her i would suspect a lifter. The MoCo recommended checking/changing at 25k. The stock lifters are prone to failure. If you installed the rocker lockers I assume you inspected the rocker bushings for play and retorqued the rocker arms properly.
Old Sep 27, 2017 | 08:53 AM
  #32
98hotrodfatboy's Avatar
98hotrodfatboy
Technically you should start your own thread... Anyways you never stated mileage? Like Evoken said, if you have more than 25k on the clock start with a set of S&S lifters and if you have the heads off right now I would also go to S&S adjustable pushrods and set the preload to .140" ... You do have a Factory Service Manual right?
Old Sep 27, 2017 | 11:05 AM
  #33
Malo22's Avatar
Malo22
Stage III
I have around 25000 miles after last rebuild. rocker arm clearances are within spec. Yes I have a manual. That's where I get all my spec from. I have checked the lifters and they all seem to be good. Sorry about not starting a new thread I'm new to using forums. I'm going to be changing to adjustable pushrods and new lifters. But the sound isn't heard around the lifters or pushrods. It's on the left side of the motor.
Thank you for the advice and the fast replies
Old Sep 27, 2017 | 11:19 AM
  #34
98hotrodfatboy
Ok little more history, how many miles were on the motor when you first rebuilt it and how many miles from them till now.
Left side is a different ball game... Have you checked your compensator and primary chain....?
I would start a new thread make a few more posts (one you get over like 5 to 8 posts then I believe you can post pictures and videos) and then post a video to help us help you...
Old Sep 27, 2017 | 11:22 AM
  #35
98hotrodfatboy
Ok little more history, how many miles were on the motor when you first rebuilt it and how many miles from them till now. Total miles on this motor and did you ever replace the valve springs? Could be getting weak..
Old Sep 27, 2017 | 12:40 PM
  #36
Malo22's Avatar
Malo22
Stage III
I had 145000 miles when I rebuilt the motor. 25000 miles since rebuild. I pulled the compensator out last night and it looks good, primary chain was adjusted properly. Yes I replaced the valves, springs,guides, and seals. this is why I'm stumped. I've checked everything I can think of. And so far everything that others have told me to.
Old Sep 27, 2017 | 02:01 PM
  #37
98hotrodfatboy
Well best though I can say is make a few more post to get to the minimum limit of posting pics and videos... The videos you need to upload to YouTube the copy the erl and paste it into a post them we should be able to pinpoint it a little better...
By the way a 145,000 miles is really good before first rebuild you must take really good care of your machine..
Old Jul 12, 2019 | 01:19 PM
  #38
1madmouse's Avatar
1madmouse
I noticed as you panned to the front cylinder the tick was more pronounced as you crossed the sparkplug, but can't say what it is. Sorry can't be more help.
Old Jul 15, 2019 | 11:26 PM
  #39
OLD 96's Avatar
OLD 96
Originally Posted by Uncle G.
Sounds like my motor has sounded for the last 116,000 miles.
Thanks for all the feed back on this subject. I thought my 1995 Road King had muy top end noise. Only too find out it is normal. A recommendation. If you have a wind screen. Running 70 mph. Bend over the gas tank. Put your head behind the wind screen to block out wind and exhaust noise and listen to that engine music.
fester1
EVO
41
Apr 16, 2018 10:10 AM
Spenser372
Mar 31, 2018 08:42 PM
jokenroll
EVO
Sep 9, 2014 03:27 PM
kennyg104
EVO
69
Aug 16, 2012 04:40 PM
jsd245
Jun 21, 2006 02:34 PM
