Super E enricher, how does it work?
Old May 10, 2017 | 12:45 AM
jurob's Avatar
jurob
Default Super E enricher, how does it work?
Picked up a 97 dyna with a Super E carb.
I noticed that when I pull the enricher ****, it closes as soon as I let it go unlike a choke.
Is that how it's supposed to work? And what is the proper way to use? I'm used to your typical manual choke that stays where you set it.
Thanks
Old May 10, 2017 | 01:11 AM
LowriderHarold's Avatar
LowriderHarold
Thanks
Since you say it has a "****" when you pull up you have to turn it 90 deg & it will stay up. If you look at it, you can see there's a roll pin thru the **** shaft & when you pull it up, you have to turn the **** , about 90 deg for it to sit on top of the boss, the shaft & **** go down thru. It's spring loaded.
Ride Safe,
Harold
Old May 10, 2017 | 04:48 AM
grbrown's Avatar
grbrown
Is this **** like the stock enricher, under the tank on the left? If so it has a 'clutch' which you can tighten, to prevent it popping back in. The enricher on my G is on the right by the air filter, which is an alternative location. Wojagot?!
Old May 10, 2017 | 09:50 AM
98hotrodfatboy's Avatar
98hotrodfatboy
The enrichment lever is part of the a/c backing plate for the E carb and there is a screw with a teflon washer to add the proper amount of tension to the lever to keep the enricher on. Either the screw is loose or it's gone. You will have to remove the a/c backing plate to adjust it...
Old May 10, 2017 | 11:30 AM
LowriderHarold
Thinking he's got one of these by calling it a ****.
Don't really know without a pic.
Ride Safe,
Harold
http://www.ebay.com/itm/Kuryakyn-Hyp...hYfsEb&vxp=mtr
Old May 10, 2017 | 12:00 PM
98hotrodfatboy
Ride Safe,
Harold
Gotcha, never seen one of those before... Thanx Harold....
Old May 10, 2017 | 03:55 PM
aces&8s's Avatar
aces&8s
Soon as the engine starts shut the enricher off and use the throttle to keep it running . Leaving it on will make a rich condition and tend to carbon up.
Old May 10, 2017 | 05:40 PM
grbrown's Avatar
grbrown
Wink
That doesn't work with my 107 and G. I leave it partly open for the first 2-3 miles before shutting off. But then I have a T-junction just a couple of hundred yards away and it is often quite cold here.
Old May 10, 2017 | 08:42 PM
aces&8s's Avatar
aces&8s
Im just repeating what S&S say's to do. I always let my engine warm up enough that I cant touch the head, by then its idling fine.
Old May 11, 2017 | 04:17 AM
grbrown's Avatar
grbrown
Red face
I must admit I never let a bike idle, just start it, let it settle for a few seconds (or a minute or two when really cold), then ride gently away.
