91 stator out. How's it look?
Old May 21, 2017 | 06:10 AM
Yankee Dog's Avatar
Yankee Dog
My guess is the connections at the plug are past their prime and the cause of your issues. As Dr Hess mentioned, I am also curious of your testing results.
The copper wire will get darker with age. Burnt or burnt smell is another good indicator besides the Ohm tests. YD
Old May 21, 2017 | 06:35 AM
RANGER73's Avatar
RANGER73
Like stated by others, it's hard to tell from the pictures if it's given up the ghost. Only a test will tell you. But at this point who cares right? 91" change it, it's already out, the hard messy part is already done.
Old May 21, 2017 | 08:28 AM
nibroc's Avatar
nibroc
Originally Posted by texashillcountry
If you go aftermarket then get Cycle Electric.
fully agree
Old May 21, 2017 | 09:35 AM
IRON1250's Avatar
IRON1250
Originally Posted by Dr.Hess
What numbers did you get when you went through the stickey?
Anyway, if it's torn down this far, put the 32 amp kit in it and call it good.
Don't remember all the numbers but it did show new battery testing good and no voltage increase between idle and 2500 rpm.
Old May 21, 2017 | 09:36 AM
IRON1250's Avatar
IRON1250
The plug in the case was in bad condition.
Old May 21, 2017 | 09:47 AM
IRON1250's Avatar
IRON1250
Originally Posted by Bingee
The Cycle Electric kit for your '91 Heritage is CE-32ALP. You get rotor, stator, and regulator. google for best price.
Great thank you. Couldn't seem to find the right kit on their site.
Old May 21, 2017 | 09:49 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Sounds like a good reason to replace it to me.
You can either get a stock replacement stator or if you go cycle electric you will need the whole system.
Old May 21, 2017 | 10:20 AM
IRON1250's Avatar
IRON1250
Gonna go cycle electric. What is the difference between the ce-32al and ce-32 alp?
Old May 21, 2017 | 10:38 AM
texashillcountry
Dirt don't hurt
Last time I spoke to cycle electric they told me the best system for a softail is their 3 phase 27 amp system.
It has something to do with the battery being surrounded by the hot oil in the oil tank.
Old May 21, 2017 | 10:48 AM
timsmcm's Avatar
timsmcm
​​​​​​​I have that same softail system. Been going strong for more than 10 years. Won't ever run another charging system. Cycle Electric all the way baby.
