piston clearance
Old Jul 4, 2017 | 07:06 AM
johnjzjz's Avatar
johnjzjz
was dome at another shop - todays gas and the hi heat it makes requires more room - 1933 to 1948 iron jug flat head engine indian chief factory piston to bore with a under 3 inch piston is .004 to .006
Old Jul 4, 2017 | 02:15 PM
Tommy C's Avatar
Tommy C
Originally Posted by dieseltime
Someone from Wiseco got back to me via email and gave m .0025 inch for minimum clearance
If you set them up tight you need to break them in slow. You don't want to seize a piston.
Old Jul 7, 2017 | 03:54 PM
dieseltime's Avatar
dieseltime
I'm actually around.0035 for clearance seems a little snug to me but I'm being reassured that will be fine
What are your thoughts on breaking in
i was told no overdrive or 5th gear for a period of time
Old Jul 7, 2017 | 08:15 PM
johnjzjz's Avatar
johnjzjz
drive it like your mom owns it and you will be fine
Old Jul 15, 2017 | 02:41 PM
dieseltime's Avatar
dieseltime
Ok so I can't seem to find anything on this
If I'm going back together with the cometic head gaskets are the o ring seals that go around the oil drain back dowels still used
Old Jul 15, 2017 | 03:33 PM
Owtlaw's Avatar
Owtlaw
No. I'm pretty sure that little tidbit of information is in the printed instructions that come with then Cometic gasket set. Ask THC about it........
Old Jul 15, 2017 | 03:59 PM
dieseltime's Avatar
dieseltime
I don't have that instructions and haven't been able to find it on cometic web site
If someone has that I'd really like a copy
Old Jul 15, 2017 | 06:36 PM
johnjzjz's Avatar
johnjzjz
no o rings with cometic
Old Jul 16, 2017 | 10:18 AM
dieseltime's Avatar
dieseltime
Thank you for that
nick@nite
Engine Mechanical Topics
Sep 20, 2017 06:30 AM
Roadflyer
Feb 1, 2016 02:08 PM
Rockwool
Screamin Eagle CVO Models
Feb 10, 2013 11:11 AM
chrisefulmer1997
EVO
Dec 23, 2010 12:32 AM
graultytc88
Shovelhead
Feb 15, 2008 03:27 AM
