I am now on my third OEM ignition module on my 1993 FXSTS in three months! Mine doesn't get hot and then re-start after it cools. It just shuts off and never starts again! The first failure was the original module, then a new OEM module and finally a used one off of Ebay.
I have run every check in the FSM twice and checked the charging system to make sure it is not over-charging. I have an extra ground strap from the battery to the engine. I have checked every inch of the wiring harnesses and tested every wire and all grounds. I replaced the pickup module last year as its' potting was melting, but it was still running fine.
What normally causes a module to fail? It could help lead further diagnosis.
The only thing I haven't checked is charging system output amperage. I have not actually done voltage drop tests on the system. My ignition switch has had contact problems as of late, so I have a new one on the way.
I am about to go to an aftermarket system, but whatever my problem is might smoke a new system too!
wrong again - 1 and 1/2 ohm coil is a 6 volt antique for the most part
3.0 ohm coils come mostly 12 volt BUT are available in 6 volt as well you need to know what your doing when ordering
5.0 coil is a point ignition coil
now variables also exists like 1.8 2.1 3.0 6 volt - then 12 volt 1.5 - 2.8 and also point ignition 4,8 and 5.2 it depends who is making it and for what
and I am sure other OHM numbers are around I did not list
to make it simple - evo 3.0 ohm or around that is fine the lower the OHM the hotter the coil is
