synthetic vs regular 20/50 oil
Old Aug 17, 2017 | 04:01 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by nordhaven
Not my experience : been running nothing but Amsoil Synth in my evolution since after break in (fresh rebuild 2years ago). After 15000 miles of touring including Sturgis this year, I have yet to add any oil between oil changes. My experience only, others as been mentioned have their own experience. Gotta find what works for you.
You just haven`t noticed your bearings skidding yet...
Old Aug 17, 2017 | 04:04 PM
nordhaven's Avatar
nordhaven
Ha, ha, maybe so!
Old Aug 17, 2017 | 04:17 PM
roadglider05's Avatar
roadglider05
Synthetic oil was originated in WWII, it would flow easier and assist in starting tank motors in extreme cold temps. This of course has nothing to do with riding or running syn oil in an evo. If all is well in any motor syn or dino oil will always work.
Old Aug 17, 2017 | 04:24 PM
Spanners39's Avatar
Spanners39
Originally Posted by grbrown
Synthetic oils were not in widespread use at the time your bike was made and you will probably find the advice, as given by Texas, is to use conventional oils, which tend to be cheaper and perfectly suitable. I use synth in my S&S engine, as that is what is recommended, but still use good ole fashioned dyno in my later bikes.
Oils get far too much coverage around HDF and there are more old wives' tales and nonsense written about the darned stuff that truth IMHO. Best if you create your own myths.....
You should use cooking oil from a sealed container and stored at 30F. The container must be opened by a female virgin from Iowa and poured on the full moon.
Add Ultima Fairy Sparkles for better gas mileage
Old Aug 17, 2017 | 04:30 PM
GARY DYER's Avatar
GARY DYER
ANY oil is OK to use in your bike as long as you change it per the specified intervals.
Dino oil = 2K ~ 3K
Syn oil = 5K ~ 6K.
I've run Amsoil/Mobil1 in all my vehicles all the way back to the 80's Vettes and Harleys. NOT ONE single oil related problem.
At the end of the day it doesn't cost any more for syn then dino due to less changes and filters and don't forget all the plastic and oil saved from garbage dumps = good for the environment.
Hell, even some Harley riders use car oil - imagine that!!!
If you ride in stop and go traffic, syn oil is better because it protects your engine at higher temps.
Syn is a little more porous then dino oil so you might want to test it in an older engine first.
Old Aug 17, 2017 | 04:49 PM
Beemervet's Avatar
Beemervet
Maaaan,
This thread has no value here. The OP is one & done. IMHO, if you need to revisit this topic submerge yourself here: https://www.hdforums.com/forum/oil-a...ted-topics-30/
Last edited by Beemervet; Aug 18, 2017 at 07:41 PM. Reason: Edited for the sensitive.
Old Aug 17, 2017 | 04:52 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Man where do you come up with this ****!!!!!
Old Aug 17, 2017 | 09:39 PM
aces&8s's Avatar
aces&8s
No problem I have non-skid bearings.
Old Aug 18, 2017 | 04:17 PM
glidein wide's Avatar
glidein wide
Old Aug 18, 2017 | 04:22 PM
98hotrodfatboy's Avatar
98hotrodfatboy
[QUOTE=Beemervet;16539887]Maaaan,
Dude, is it necessary to post something like that???????
Please edit and take it out..........
